44066
Is there any way to stain or color stainless steel without dipping or heating? [California]
February 17, 2007
I'm a brick layer and I just purchased a level from "Crick Tool" that is super duper costom. I would like to costomize it further by coloring the metal workings on it. It is a wooden level and the binders "metal reinforcing rails on the edge" are permenantly affixed to the wood. Is there any way I can impliment a color onto the stainless that will be fairly durable without damaging the wood?
Thank you very much,
Steve-o : San Diego
Edward Stephen Verduzco
Modern Masonry - San Diego, CA, USA
February 23, 2007
You can use next solution:0,1 lit sulphuric acid(1,55 density!)/1,3 gm sodium bichromate, 25 C temp.,5-10 minutes -works only on grease and oxide free surfaces .Nasty and poisonous stuff-be careful,use rubber gloves and safety goggles, avoid any direct contact with solution. Hope it helps and good luck!
- Zagreb, Croatia
