44064
Electroless nickel plating peel off and
corrosion problem / Pin holes in Aluminum surface
[India]
February 17, 2007
Dear All ,
we manufacturing parts using Exctrusion Aluminium Alloy - 2014A - h15
grade / T6 WP condition material. After getting the machined
aluminium housing , we do electroless nickel plating on this
aluminium part . This is has to withstand very hard & tough
environmental conditions ( -40 deg to +150 deg C , Hot & cold
temperature cycling ) .
The problem I face is 2 types ,
1. we observe pin holes and porosity on the machined part of surface
of aluminium housing
2. Due to this the electroless nickel plating is getting peeled off
during various test conducted to test the finished aluminium
housing.
3. Even this plating is getting corroded during salt spray test
conducted for very long duration .
what would have been the problem which we face now???
pls give your suggestions.
T.S.Sivakumar
Electronics manufacturing - India
February 23, 2007
Presuming that typical processes were performed between machining
and EN plating, possibilities include:
Dull tooling or improper cutting fluids.
Inadequate cleaning.
Over-etching.
Inadequate desmutting.
Poor zincating (thin, double zincate is preferred).
Poor strike coating (alkaline EN?).
Inadequate EN filtration.
Inadequate EN agitation.
Excessive byproducts in EN bath.
Inadequate additives (stabilizers, anti-pitting, etc.) in EN
bath.
Inadequate rinsing between any steps; DI water is necessary before
the 2 EN solutions.
For pretreatment, zincating and a neutral electrolytic nickel strike
(if so desired), see ASTM
B253 [link is to spec at TechStreet], 'Standard Guide
for Preparation of Aluminum Alloys for Electroplating.' Also, many
metal finishing books are available:
http://www.finishing.com/Books/index.html
If using 'homebrew' EN solution, this is often 'penny wise and pound
foolish.' Proprietary solutions produce quality coatings over a
longer bath life and come with professional advice.
Ken Vlach
- Goleta, California
February 23, 2007
All of what Ken said is very true. But, the best plater in the
world can not overcome cheap metal that the housing is made out of.
There should be absolutely no visible pits after machining.
- FL
