44056
Cast iron garden statue is beginning to
rust [North Carolina]
February 16, 2007
I just bought what I think is a cast iron statue with a powdery
blue finish. It does not look painted. I have not taken it out side
but had it in the garage where moisture has gotten to it. It is
starting to rust and I do not want it to rust. I like the color and
finish that it has, but feel I must do something to it before the
rust spreads. I actaully bought it to put in the yard, but will not
so until I know it is protected. I don't know enough about the
finishes of cast iron to know what to do to prevent the rusting and
hopefully preserve the finish
Virginia Cornell
home owner - Jamestown, NC
February 18, 2007
The blue finish is probably a thin coating of a metallic patina. I
think it's probably beautiful but delicate. I don't think such a
finish is made for outdoors. Cast iron that is to be outside without
rust probably requires paint. But you could try a simple clear coat
like 2 or 3 thin layers of Krylon clear spray and it might last a
couple of seasons before you have to paint it.
finishing.com Inc. - Brick,
NJ
