44026
How to maintain pyro-copper? [UK]
February 15, 2007
I run a pyro-copper plate line, using the copper plate as a mask for heat treatment. The normal chemical analyses is carried out, with twice weekly checks of pH, ammonia, copper and pyro to copper ratio. I have just introduced Hull cell into the checks and this has enabled me to get better control. The only grey area I have is cyanide contamination (due to the strike), should I only react from the results of the Hull cell. Or treat with hydrogen peroxide on a weekly basis. If so what is the procedure.
Peter O'Shea
Plating Shop - Somerset, UK
February 16, 2007
Peter,
If you are dragging in Cn to the pyro Cu bath you will have to adjust the ph downward often. If it does become a problem, rinsing after the strike should be increased. If that doesn't work a mild potassium hydroxide dip before the pyrophosphate Cu will help. Good Luck!
Mark Baker
Process Engineer - Syracuse, NY, USA
February 19, 2008
Hello!
as a follow-up to this topic, I was wondering if anyone knows of a good ammonia monitoring protocol for the pyrophosphate copper plating process. The literature has been a great help for analytical chem techniques to monitor e.g. pyro/Cu ratio, but I have found that maintaining the correct ammonia concentration has still come down to empirical means: "From experience I've learned I need to add X mL/L per day" etc.
I would like to quantify the concentration of the active NH3-containing species in my electrolyte somehow in order to keep it as constant as possible. Any ideas?
Thanks in advance!
Iain Brooks
- Toronto, Ontario, Canada
