44021
Soldering Ventilation
[Malaysia]
February 13, 2007
(a) The fume from the wave soldering machine is leaking to the
surrounding although it is enclosed and attached to the local exhaust
ventilation system with a capacity of 5000 CFM.
(b) Current local exhaust ventilation system or the portable exhaust
fans are found not efficient in extracting the fume during soldering
at single workstation.
Do you have any good recommendation to solve the above problems with
cost-effective and space-saving technology?
YE MEI PING
ELECTRONICS MANUFACTURING - PRAI, PENANG, MALAYSIA
February 16, 2007
Hi Y
It's somewhat difficult to help you when you don't give one any
sizing data nor hood design.
The most IMPORTANT thing about fume capture is to have the fumehood
as CLOSE AS POSSIBLE to the source.
A minor point, which determines somewhat the fan static pressure, is
the sizing of the ducting ... in your case I'd opt for max. max.
3,000 fpm.
Come back with a sketch ... and I ... and others .... will try to
help you better.... OK?
Another point which emerges is the given fan sizing. Are you
pluperfectly SURE that the fan is 5,000 cfm? Are you sure that the
fan wheel isn't the wrong way around?
(Yup, I've sure seen that, too!) ...I am a great disbeliever, based
on experience, of what others tell me.
Freeman Newton
- White Rock, B.C. Canada
