44006
Recovery of aluminium anodizing sludge
[New Zealand]
February 14, 2007
Hi..
I am just wondering what would be the easiest method to reuse alumium
anodize sludge as a flocullant or any other simple procedure that can
be used to reuse anodized waste?
Biren Patel
student - New Zealand
February 15, 2007
Typically there is no "sludge" from the anodizing tanks. Baths are
typically decanted on a regular basis to keep the Al content at an
acceptable level. Al is not a regulated material, so the decanted
solution is normally ph adjusted, and discharged to sewer.
Marc Green
anodizer - Boise, ID, USA
February 18, 2007
If you anodize a fair amount of 2000 or 7000 series aluminum
alloy, you very probably will exceed the amount of copper that you
are allowed to go to the sanitary sewer with.
- FL
February 20, 2007
Luckily, for me, I deal almost exclusively with 6061, and 5052
alloys for the semiconductor industry. But you are correct, James,
without some type of filtering, it's very possible to exceed Cu
limits in the bath.
Marc Green
