44001
Tackling corrosion in fertiliser gas
scrubber units [India]
February 13, 2007
Hi,
I am a mechanical engineer in NPK fertiliser unit. Our Gas Scrubebr
and Ammonia scrubber system is susceptible to frequent leakages in
the shell and pipe areas. Our current scrubber is SS316L make and we
have unsuccessfully tried rubber linings also in the past to tackle
this problem.
Can anyone suggest options/ alternatives in this area. Our Chloride
levels are < 10000 ppm with average liquor temperature of 75
C
Thanks & regards
Dibyendu Ghosh
Mechanical Engineer - India
February 14, 2007
Hi Dibyendu,
Have tried tried plastics ????
Maybe a PVDF coating would work. This is, as you probably know, a
quasi fluorocarbon BUT on the negative side, it's not happy at all
with high pH but super in acids.
Then there are the weldable flurocarbons which, with a fibreglass
backing, a so-called dual laminate, would be far superior to 3l6L or
any Ni.Cr alloy.
There are also mist eliminator blades available in PVC, PVDF and BUT
also in PP ... good for l2 micron capture if made correctly.
I have successfully replaced mass transfer scrubbers but those were
in PVC which is nbg due to your temperature ...
Freeman Newton
- White Rock, B.C. Canada
