Nickel recovery by electroplating
Q. From the literature, I found that the optimum condition for my nickel electroplating is as follow:
electrolyte concentration: 100 g/L of 450 ml NiSO4
Temperature : 60 °C
pH : 4
Boric acid : 20 g/L
However, while I was running my experiment at 15 Volts for the plating, the temperature was increased 30 °C for every 10 minutes. So after 20 minutes, the temperature of electrolyte was increased until 90 C. My question is how do I control the temperature to carry on my experiment and the deposition for my thick nickel plating will not be affected?
I wish to plate a thick nickel 'nugget' from my experiment. please share your experience.
Haf_Ang
Chemist - Malaysia
A. 15 volts is mega too high for nickel plating. Drop the voltage to 4 V for a start and use a lot longer time. High amperage nickel plating requires extreme agitation.
You might try putting your anode a little bit closer to the part (cathode). For beaker plating, you could go to 1 inch apart for many things.
Set your beaker in a large glass dish that is about as deep as the liquid level of the beaker and add an inch of crushed ice to the dish. Add more as the temperature rises.
You can agitate your solution with air from a fish tank air pump.You will need a control valve in the line. Do not use a fish tank air rock as the solution will dissolve it. You can put holes in the plastic tubing on the bottom of the tank with a drill or a red hot paper clip. Weigh the tube down with a glass rod or stainless steel wire.
Q. Thanks, Mr James Watts. But now I meet a problem that instead of using 15 Volts, 4 volts electroplating take much longer time to get the plating. So I hope to maintain the high deposition rate and its temperature as well.
I'm thinking whether I put the anode and cathode too close that generates high temperature to the system, the distance between the electrode is about 6 cm far away. Is the distance a factor for temperature raising?
Mr James, about your suggestion of agitation of air, the temperature will not go up so fast, but after a period the temperature will still increase slowly. How do I maintain the temperature at only 60 °C? it really a big problem to me.
And also, I found that the Stainless steel anode that I used will pollute my electrolyte to produce my nickel plating because the dissolution of the SST will dissolve it high content of iron into the electrolyte. And if I use the nickel as anode the dissolution rate will be faster than the SST anode, and I found that it is not cost effective to my nickel plating. So do you have any ideas about what kind of the anode used in my experiment, that is low dissolution and high oxygen evolving? Thanks//
Haf_Ang [returning]
Chemist - Malaysia
"Selective nickel electrowinning from dilute electrolytes"
by Gerald R. Smith
A. Everyone wants to plate faster, Haf, but they'd also like cars that go 200 MPH, get 100 MPG, and carry a family of 7 in comfort. A starting point is to compare your current density with published values. You probably will not successfully plate at much over 40 amps/ft2. Where are you now?
The closer the anode to cathode spacing, the lower the voltage; and the lower the voltage, the lower the temperature rise. But you certainly need nickel anodes, cost effective or not. It is hard for us to guess what we need to tell you about if we don't know what you know and what you don't. That's an advantage of books: there's enough room to cover everything. Do you have access to a few books on nickel plating? Good luck.
Q. Mr Mooney, my knowledge of electroplating is all from self learning, basic chemistry knowledge, and some literatures from internet. So I need some professional ideas to get my electroplating successful. Or if Mr Mooney can suggest any books/websites that related to my experiment, please kindly share with me. Thanks in advance.
By the way, I have a question regarding to the spacing between the electrodes and temperature. I previously thought that the closer the spacing, the higher the temperature, because while the distance between the electrode closer, the conductivity will be increased, and it generates the heat, thus temperature raise. However (if I did not misunderstand), Mr Mooney do you mean that if the spacing between the electrodes closer, the voltage will be lower and also temperature become low? is totally opposite to what I assume.. Then my assumption was going to the wrong way?
Actually, the main purpose of my experiment is to plate the nickel out from the electrolyte as much as possible, and not kind of decorative plating. So, is it really necessary to use nickel as anode? because I will gain the plating yield from the dissolution of the anode, the extraction from the electrolyte is meaningless then..
Haf_Ang [returning]
Chemist - Malaysia
A. Sorry, but after 3 postings and 3 responses I still don't quite understand what you are trying to do or why, Haf. But the closer the anodes to the cathodes, the lower the solution resistance, so the lower the voltage you can use, so the less power you waste to the solution and lower the heating effect.
As for other websites to visit, please google for Ohm's Law. After you feel comfortable with that, google for Faraday's Law. Those will arm you with the basic understandings you will need to understand the relationships between voltage, current, spacing, plating time, thickness of deposit, etc. For books, any of the "must have" texts on our Books page will be tremendously helpful.
You will find it impossible to plate nickel to low levels this way though. The "efficiency" will drop faster than the nickel concentration. That is, as the nickel level drops, more and more of the applied electricity will just release hydrogen and oxygen instead of depositing nickel. To recover nickel from waste, you generally need super large surface area cathodes (reticulated copper or carbon) and extreme agitation. Good luck.
Relationship of current density and inter-electrode distance in Nickel electrowinning.
Q. Hi, I had been advised by Mr Mooney that >40 A/ft square won't give successfully plating, so I control my current density below 35 A/ft square with the space of inter-electrode of 2.5 cm. But the plating efficiency is not good in my 20 A current experiment. So I m wondering whether inter-electrode distance is too close resulting in depleted metal surrounding the cathode or the current density is too high for good plating efficiency? Or any information about relation between the electrode gap and the current density?
Haf_Ang [returning]
Chemist - Malaysia
A. Hello again, Haf.
You will need a platinized titanium anode if you will not be using nickel anodes. There is certainly a relationship between solution agitation, interelectrode distance, solution concentration, and maximum successful current density -- but it isn't a simple formula. Each of those variables interacts with the others.
Your close interelectrode spacing helps keep solution resistance down, which directly keeps plating voltage down, which directly keeps power consumption down -- and power consumption is the same thing as heat. So you do not want to increase the distance, you want to increase the solution agitation!
In your first posting you said your object was to make a nickel nugget as an experiment. When we advised what parameters to use, you said plating that way would be too slow and nickel anodes are too expensive, which didn't seem to make sense if you were trying to make a nugget. But when we tried to clarify the issues in that new light, you then said the answer was no good because your object was actually to remove the nickel from the solution. Then we said that will not work properly with this setup because the efficiency will plummet as the concentration goes down. Now you are saying the efficiency is too low.
Can you please help by forthrightly describe exactly what your goal is -- what exactly you are trying to do and why? In other words, are you a student trying to make one nugget, or are you an engineer trying to build an electrowinning plant for the production of nickel, or are you trying to develop a process to remove nickel from waste streams as a pollution control measure, or what? As you can see, we can't efficiently help you get where you trying to go if you don't tell us where you're trying to go :-)
"Electrolytic Separation, Recovery and Refining of Metals"
byG. Gore
from AbeBooks
Q. I have a question regarding Nickel electroplating. I am a student at a university and I'm planning to work on a thesis that would recover pure Nickel metal from a Ni-Cd battery through electroplating. The battery would be dissolved in sulfuric acid. The electrolyte would contain Ni, Cd, Fe, Co, Zn and other metal ions. Using stainless steel as cathode and Pb as anode, do you think it would be possible to electro-deposit pure Nickel alone under a specific current density?
What do you think are the conditions that could produce such result? Your response on this matter would be highly appreciated.
Paolo Pulido
- Diliman, Quezon City, Philippines
September 4, 2008
A. Hi, Paulo. No, I don't think you can recover pure nickel that simply. But you may be able to precipitate the iron with peroxide, dummy out some of the other metals, or precipitate them out. Nickel-cobalt is a plateable alloy, so I'm not confident that you will be able to plate one preferentially.
I need to electrowin nickel from sulphate solution, prepared by dissolving nickel carbonate in sulfuric acid. Solution does not contain any impurities other than chromium and copper below 100 ppm. Nickel concentration in solution nearly 60 to 80 gpl but I have to go down to 15 gpl. pH 3.3 to 3.5 by NaOH.
I need to know what is ideal amps to be applied at anode and volts at electrode to deposit nickel. Any recommendations for operating parameters shall be of help.
K. S. Shah
- Mumbai, Maharashtra, India
March 21, 2016
A. Raise the temperature to 140 °F, and plate at 20 ASF, or higher current density if well agitated. Additives are not needed, but sodium lauryl sulphate might be helpful to reduce pitting.
Lyle Kirman
consultant - Cleveland, Ohio USA
