HI TEMPERATURE ANTI-GALLING COATING
I AM LOOKING FOR AN ANTI GALLING COATING TO USE ON 1" AUTOCLAVE TYPE PIPE COUPLINGS THAT WILL CYCLE BETWEEN 50 AND 650 °C. THE THREADED STAINLESS STEEL AND INCONEL 625 PARTS ARE DISASSEMBLED/REASSEMBLED IN THE FIELD ON A REGULAR BASIS FOR REBUILDING AND CLEANING. CAN YOU SUGGEST A COATING OR PLATING THAT WE CAN HAVE APPLIED TO PREVENT THIS FROM HAPPENING? THREADED COMBINATIONS ARE :
INCONEL TO INCONEL
INCONEL TO STAINLESS STEEL
CARBON STEEL TO STAINLESS STEEL
CARBON STEEL TO INCONEL
CARBON STEEL TO CARBON STEEL
JOHN AUGUST LOMBERK
CITY OF ORLANDO - ORLANDO, FLORIDA, USA
Teflon tape sounds like the best bet. It is also cheap and renewable as required. I would not use anti-seize or pipe dope.
Electroless nickel boron iaw AMS2433 type II or Enkl/PTFE iaw AMS2404 would likely solve your galling problem.
Patti Kientz
plater - Santa Ana, California, USA
I would be concerned about cycling between 50 and 650C, as PTFE will not survive these temperatures. I am also dubious about the using electroless nickel at these temperatures as there could be a risk of embrittlement, but perhaps someone with more experience of electroless nickel can shed some light on that. Personally, I would suggest giving the parts an electrolytic coating of silver. Use a cyanide silver strike to get good adhesion and it should overcome your galling problems. Silver is a pretty efficient depositor, so there shouldn't be too much risk of hydrogen embrittlement either.
Use Brush Plating or Selective Plating. We use it daily for our production.
Sunny Tan
Shall be thankful to know which of the various suggested answers you adopted and what was your experience
Ranadev Chatterjee
- Khobar, Saudiarbia
April 10, 2011
