How to Make Aluminum Corrode / Patina?
Q. Reading this page, it occurred to me that a strong vinegar or acetic acid [on eBay or Amazon (adv.)] might corrode (cast) aluminum white. I'm looking to change the finish of some cast alum pond herons but wish to maintain an AGED appearance. Any takers?
Doug WilsonTinkerer - Ocala, Florida, USA
September 3, 2023
A. Hi Doug,
Please e-mail to mooney@finishing.com, for posting here, a good pic of the herons, with other stuff in the pic so color can be judged -- and people may hazard a guess. But we have no idea what they look like currently or what you object to about the current finish. Castings are high in silicon so virtually anything you do chemically (except applying hydrofluoric acid which is a terrible safety hazard) will probably darken them rather than whiten them.
Maybe try oven cleaner [on
Amazon (adv.)] in an inconspicuous spot and see what you learn? But although I'm not experienced with his techniques, I think Al Sterling offers the best answer.
Q. I have a client who wants a pitted finish on a sheet of 16 gauge aluminum. I know aluminum does not rust, but that doesn't mean it won't corrode, how it corrodes though is where I have no idea.
Is there anyway possible to get a finish like this? Is a week enough time for a pitted finish?
I looked over some articles on this site and have found that alkaline and aluminum are not friends. Would soaking the plate in a rich alkaline heated environment be the answer?
I think/believe he is going for a simulated rust, pitted feeling of steel, without all the iron dust, weight, and so on.
The piece is not going to be used for anything structurally speaking; he is a graphic designer so it is something along the lines of that use.
Fabricator - San Jose, California, USA
A. Hi John. Bare aluminum can corrode quite readily, but the problem is that the corrosion products will not look like what he is envisioning. Corroded aluminum is not brown with a fine grain, like rust on tool steel. Rather, the corrosion products are white, random pitted, crusty volcanos, and somewhat like salt stains. If you have a sliding shower door more than a couple of years old, look at the corner joints -- the extrusions are anodized, but cut to length after anodizing which exposes bare aluminum (at least if you have cheap ones like I do). I'd suggest a decorative rust-like paint or iron paint if you want rust color. Good luck.
Q. Ted, thanks for the reply.
"Rather, the corrosion products are white, random pitted, crusty volcanos, and somewhat like salt stains."
I told him that the corrosion produces a white salty-like finish. He loves the look. I had 15 year aluminum frame I showed him and he loved the look.
Is there any way to rapidly speed up the corrosion of aluminum to make the piece look like it has been sitting for 15 years like my frame?
Thanks in advance!
You guys have a great website here!
A. Try glass bead blasting.
Ken Vlach [deceased]- Goleta, California
Finishing.com honored Ken for his countless carefully researched responses. He passed away May 14, 2015.
A. Any very alkaline solution (pH8,5 or more) must etch or corrode aluminum. Try sodium carbonate / washing soda [affil links] 10% (or even sodium hydroxide 2-5%) -- mix it with some sawdust or sand,c over your object with this mix, after a few days it must be ok. Good luck!
A. Try a mixture of 5% sodium hydroxide with about 5g/l sodium chloride in it (common salt). Mix this with some sawdust and leave it for a few days on the aluminium surface - it will give a corroded finish. If it is not corroded enough, put the sawdust back for a few more days or until it is the finish you need. Make sure you keep the mixture moist.
A. If you put bleach [adv: bleach/sodium hypochlorite in bulk on eBay or Amazon (adv.)] and salt onto the aluminum, especially a gel bleach so that it sticks (I used toilet bowl cleaner) then cover with plastic you will get a pretty good patina in an hour.
Julie Anderson- Boise, Idaho, USA
October 4, 2014
Hi Julie. Thanks for the posting and illustration. Only trouble is, your example isn't aluminum :-)
It looks like a tomato juice can or pineapple juice can made of steel with a tin coating. We can see the brown (iron) rust on the lid seam.
October 2014
A. ferric chloride [on eBay or Amazon (adv.)] (etching fluid) and apply heat.
Ben BrickwoodSesame Design - Kingston England
November 17, 2016
Q. How could I make disposable aluminum pie plates look red/rusty? It seems like there's some discrepancy (above) about the color of corroded aluminum...so are you saying there is a spray or paint application that could achieve that look better than actual corrosion? Thank you!
April Heimerle- Nashville, Tennessee USA
November 5, 2017
A. I hope I'm understanding the intent of the question. From nearly 40 years in the custom metal graphics industry, I can share that making one metal alloy item look like another metal alloy item, or exhibit the "natural oxidation" effect of the intended metal (patina), is certainly possible. It is done by applying an appropriate "topical color-inducer/oxidant" or a "topical pigment." I recently created a cast aluminum historical military plaque for a client, and when asked to match the near century old cast bronze plaques already in place, gave him a color palate from which to choose. He found a color chip that closely resembled the natural patina bronze. It was a rather consistent blue-gray. While not exact, it was very close. If he chooses to send the plaque to our facility, we could, if supplied with photos of his memorial and plaques, come a bit closer.
My point is that when using a core metal, and then asking for a coloration on the metal, one's immediate solution is to simply use a topical pigment. The coloration-artist must have enough experience, but even creating a "ferrous oxidation mark" on an aluminum surface is totally doable.
One should also understand and differentiate between a "mechanical finish", which is usually created on the bare metal using some form of abrasive, and the "topical finish", which refers to any chemistry, liquid or solid, applied to the surface of the subject material. I see the solution to this question as being a selection of appropriate topical chemistries. And frankly, this is a very common practice for the entertainment industry and the prop departments and shops.
Know that "sodium hydroxide", as mentioned by others as a rapid acting oxidant, (the basic chemistry of drain cleaner) is sometimes used as an etchant of aluminum; meaning it will quickly oxidize and essentially remove the aluminum as though one were mechanically engraving with a rotary bit. In its place there will be "aluminum oxide." Of course, purposeful etching for graphics also most usually includes creating a protective stencil that, when applied to the virgin surface of the metal/aluminum, only allows the etchant to "selectively etch" the metal surface. I'd estimate that with 3-5 cans of Rust Oleum spray paint, and some stencil material custom cut to mimic a random rust-mark, and after one properly prepares the metal surface, the replication of ferrous oxide marks could be created.
Al SterlingDesign-Production of metal architectural graphics - Glendale, California
March 3, 2018
Ed. note: Thank you Al! Can't speak for others, but the editor (who spent his entire career in metal finishing) learned a great deal from your posting -- including that there are vast holes in his education :-)
Al Sterling I love your answer. So pretty much paint it?
I have client who lives to throw the impossible at me.
We have refinished and repurposed a door from another property and put it in the original manufacturers aluminum frame (original to the house not the door, lol).
Of course the outside is in now and the design but he wanted it for the stained glass. I already have made two metal L kick plates so I can lose the gap left at the bottom.
I was racking my brain on how to finish the frame while still in.
Long story short, thank you for your answer. I knew painting it was my only option but now the stencil part has stopped eluding me.
Handyman and world rocker extraordinaire - Camp Verde, Arizona
April 4, 2022
Ed. note: Welcome! Feel free to visit anonymously! But our 35-year legacy of warm aloha is incompatible with anonymity; please only post with your full real name.
A. TJ ... it's been a while since my post. I appreciate your response and can understand the challenge of trying to translate a client's 'vision.'
While not permitted by forum policy, which I understand, you might want to search for a manufacturer of faux-finishes (in spray cans) that literally has formulated and provides our industry with just about any 'patina' finish you might want to impart on any metal surface. I've such a product at home to turn galvanized pipe into dark rubbed bronze to match plumbing fixtures. With topical finishes, I've found almost anything is possible. Although, its durability, like any clear coating or pigment, is susceptible in its unique way, to handling wear, UV exposure and general weathering.
Al SterlingManufacturer of custom architectural graphics, plaques, letters, logos - Al in SoCal
April 4, 2022
Thanks Al. It's true that we discourage praise/slams of brands & sources on this no-registration-required site ( why?) and we don't much like links or contact info because, although google is designed for live searches, this site attempts to be a permanent reference, and virtually no links, phone numbers, or e-mail addresses have any permanence -- so we're constantly playing whack-a-mole on 60,000 threads going back 34 years now. But after two highly educational postings I don't think there's any harm in you mentioning your company name or that of the faux finish supplier. Thanks. Luck & Regards, Ted Mooney, P.E. RET Striving to live Aloha finishing.com - Pine Beach, New Jersey April 2022 |
