43094
Comparison betwen galvanizing and powder
coating [UAE]
November 21, 2006
Dear Sir,
We are a leading company in Dubai, and we have a project in which we
have to do a mild steel balustrade laying 2 meters above the see
level. The Arabian Gulf are is a high-humidity area, and so, the
corrosion issue is the priority number one for us. The consultant is
asking us to apply the powder coating, byt we cant do that since we
can't make any kind of welding after the powder coating, plus another
difficulties and that shall make the powdwe coating process too hard
to be used. We propsed to galvanize the material and then to apply a
wet coat. Is it acceptable? and how can I proof that to the
consultant?
Thanks and Regards
Mohammad H. T. Hussein
- Dubai, United Arab Emirates
November 22, 2006
Hi,
I would like to suggest you to use powder coated aluminium extrusions
for balustrade (especially done by some QUALICOAT certified
Powdercoater).
If you want to use mild steel then you can contact your local powder
manufacturer who has all the answer for you.
Srimay Basu
- Dubai, U.A.E.
November 25, 2006
Galvanized balcony railings near the sea will last longer than
painted, but will still corrode. Galvanizing protects by the zinc
corroding in preference to the steel, but when its all gone, then the
steel rusts.
Marine environments are one of the most aggressive, so you should be
not considering either / or, but both.
Hot Dip galvanizing to
ISO 1461 [link is to spec at TechStreet] followed by
powdercoating, or perhaps solvent based paint. But either of these
two top coats needs a competent pretreatment to ensure adhesion ot
the galvanizing.
This duplex coating should give 15+ years even in this environment. A
factory based application would be far better than a site applied
coating.
Welding after coating is to be avoided. It will destroy any coating.
You should fabricate to avoid welding. Use bolted connections. If
making to fit an existing site, then measure well and make to fit.
Don't weld coated steel.
Geoff Crowley
- Glasgow, Scotland
