43091
Can the salt solution be recycled after
being collected from salt chamber? [India]
November 21, 2006
Can the salt solution be recycled after being collected from salt
chamber?
Suppose we use 5% NaCl Solution for salt-spray chamber,PH value was
adjusted according to ASTM B117, Now if we get the collected solution
with having PH in the same range as it was earlier, then can we use
the colleted solution again and again?
Daitari Kamila
Jindal Stainless Limited, Haryana - Delhi, India
November 22, 2006
Hi,
Per ASTM B-117 [link is to spec at TechStreet],
paragraph 4.2 which states that "drops of solution which accumulate
on the ceiling or cover of the chamber shall not be permitted to fall
on the specimens being exposed."
4.3 states that "drops of solution shall not be returned to the
solution reservoir for respraying."
I never heard of anyone recycling their collected salt fog.
Bill Duttlinger
- Naperville, Illinois
