43075
Addition of Cadmium metal in Cadmium Plating Bath [Pakistan]
November 17, 2006
We analyse Cadmium Plating Bath for cadmium metal, Chlorides and Sulfates. Cadmium metal content of the bath is at lower limits. We have Cadmium anodes dipped in the bath but it increases metal content very slowly. How can we add Cadmium metal other than anodes to the bath already prepared.
thanks.
Zakir Shah
chemical engineer - Karachi, Pakistan
First of two simultaneous responses -- November 17, 2006
You use cadmium oxide. Wear a respiratory mask so that you do not inhale any as it will give a dust cloud if you are not extremely careful.
- FL
Second of two simultaneous responses -- November 17, 2006
Simply put cadmium oxide into a filter bag and hang into plating bath with circulation can increase cadmium content.
David Shiu
You generally add cadmium oxide. I suggest you get a reference book.
Gene Packman
- Great Neck, NY
