43051
DI water corrosion in steam sterilizer
[Florida]
November 16, 2006
Hi. I'm a Senior Engineering Technician at UF with a corrosion
problem in a relatively new (~2 y.o.)steam sterilizer used in our
biochemical labs. The boiler and chamber are apparently SS (316?),
copper heating elements, brass end-plate, and some black-pipe
plumbing.
The scientist running the research group requested that DI be used.
But, this is the second heater failure since the sterilizer was
installed. The boiler and heaters were covered in a reddish-orange
gunge and the black pipe had external corrosion (white salts) at the
junctions with the SS boiler.
The question is this: should we continue using DI, monitoring the pH
and conductivity, or switch to RO or some other highly-filtered water
source?
Lawrence H.
University of Florida - Gainesville, FL, USA
November 20, 2006
None of the above answers will stop the designed-in corrosion. Is
this a once-through system using live steam, or a closed-loop system
with condensate return? If closed-loop, add treatment chemicals to
protect the various metals – see GE Water and Process Technologies.
With a live steam system, make everything 316L stainless and use DI
water.
The U of F has a very good Materials Science and Engineering
Department. Find someone interested in corrosion problems.
Ken Vlach
- Goleta, California
