43041
Electroless Nickel
[Arizona]
November 15, 2006
I have some electrical circuit breakers in a wastewater treatment
plant and they get corroded due to the existence of hydrogen sulfide.
Any idea if I can use EN (electroless Nickel) plating process to
plate the DC contacts of the breaker that are made of copper with out
affecting the contact resistance too much. FYI the applied voltage on
the DC contacts are 48 Volts.
Taha Moahmmed
- Phoenix, AZ, USA
November 15, 2006
Contacts are often electroless nickel plated, including almost all
of the contacts on battery chargers of every description. After you
have sample parts run, you could measure the resistance to be sure .
. . but to me it sounds like a perfect application.
finishing.com
Brick, New Jersey
November 17, 2006
The major limitation with the use of nickel coating for connector
contacts is its tendency to form a hard and insulating oxide film.
Since the prime requirement of a coating for use in connector
contacts is to maintain a low contact resistance, nickel is not
considered as a suitable choice in many instances. However, nickel
plating has long been used as a popular and cost-effective choice for
battery contact material in applications such as flashlights, toys,
etc. where the current load is sufficient enough to break the oxide
film on the nickel coating.
Chudnovsky [1] has reported that electroless (EL) nickel plating
withstands the corrosive, hot and humid atmosphere much better than
traditional silver and tin plating, which have been nearly destroyed
in H2S environment. According to her, it is an effective alternative
to silver and tin plating for protecting circuit breaking equipment
from corrosion up to one year without significant discoloration in
corrosive atmosphere. Dervos et al. [2] have recommended that EL Ni-P
coating could be used as a low-cost stationary contact material and
it can perform well even under adverse working conditions. EL Ni-B
coating is considered as a useful alternative for gold and silver in
microelectronic devices. EL Ni-B coating possess good solderability
compared to EL Ni-P coating because its oxide layer is thin and can
easily be penetrated by the solder. Dervos et al. [3] have
recommended EL Ni-B coating as a possible solution for low-cost
stationary contact material.
1.B.H. Chudnovsky, Proc. 49th IEEE Holm Conference on Electrical
Contacts, IEEE, 2003, p. 98.
2.C.T. Dervos, P. Vassiliou, J. Novacovich, C. Kollia, IEEE Trans.
Comp. Packag. Technol. 27(1) (2004) 131.
3.C.T. Dervos, J. Novakovic, P. Vassiliou, Proc. 50th IEEE Holm
Conference on Electrical Contacts and the 22nd International
Conference on Electrical Contacts, IEEE, 2004, p. 281.
T.S.N. Sankara Narayanan
- Chennai, Tamilnadu, India
