Chrome plating tank contamination
Q. Hello sir. I have a problem in chromium plating where there is rubber mixed in my chromium solution. What's the solution for this?
Ahmed Munir- Lahore Pakistan
August 4, 2022
A. Hi Ahmed. These days 'rubber' rarely means the product of a rubber tree, but usually means one of many varieties of artificial rubber. But yes, I believe that chromic acid is able to dissolve most of them, and will result in dissolved organic molecules that can mess up a chrome plating bath.
If you are sure that significant contamination with rubber is the problem, I doubt that anything practical can be done to fix it, and the solution will have to be dumped. But what problems are you experiencing, and what is the contamination level or evidence that rubber contamination is the problem?
Q. I have iron and copper in my Hex chrome bath. What is the remedy? Who supplies equipment for such removal of impurities? Can dummying at low current density help to remove iron?
Kaushik Magiawalaplating shop employee - Gandhinagar, India
A. Iron contamination will cause hazy/cloudy deposit and lower the plating rate. Dummy at low CD can help to remove iron. However, bath dilution is recommended should iron content be too high.
David Shiu
A. Use porous pot technology. It also reduces the trivalent.
James Watts- Navarre, Florida
A. There is a chrome purification system called a porous pot you should research.
Todd Osmolski- Charlotte, North Carolina, USA
A. Mr Magiawala
It is practical to sell off the bath to a manufacturer of Chromating chemicals in your city.
Make up a new bath. Mask areas where no plating occurs and prevent further build up due to etching out of the offending metallics again.
Asif Nurie [deceased]
- New Delhi, India
A. A porous pot is the key to reducing trivalent-copper and iron.
This product is excellent I have used them for years and works better than dummying.
Be sure to keep them running and fresh clean solution in them at least twice a week or more couldn't hurt just produces more waste. Be sure to block off before doing a reverse if using the same rectifier to plate with. The costs is around $1,100 U.S and are for tanks around 1,000 gallons. They make larger ones but are harder to get in and out of the tanks to check and clean. Just use a hand pump to change solution and take out once a month to clean and check plastisol coating. This is a very good investment.
- Atlanta, Georgia
A. Dear sir, there is an instrument called AAS
[on
Amazon (adv.)]. Analyse your bath for trivalent, copper, zinc, iron, etc. remaining in the bath in ppm. If they exceed some limit then there is a problem, otherwise no worry.
Ajay Raina
Ludhiana, Punjab, India
Thanks to all. I unfortunately saw answers very late. I never got indications of answers and was wondering why no response.
Kaushik Magiawala [returning]- Ahmedabad
August 14, 2021
Ed. note: We always notify readers when their posting is published and of every reply. Such notices include a link so you can find the posting, but unfortunately some people's filters are set up to redirect anything with a link to their spam folder.
If you would please 'whitelist' <mooney@finishing.com> it will solve the problem.
Chrome Plating Pitting and Metals Contamination
Q. I am a chemical engineer, just started working in a chrome plating shop. We are having some pitting problems, and I am slightly confused about what I have read about chrome pitting and metals contamination. Some people say metals contamination will only cause rough chrome, bad conductivity, but not pitting. Others say metals can cause pitting. (when I say metals, copper and iron seem to be the ones that matter)
Can anyone help set this straight?
If metals do cause pitting, what levels of contamination do I need to stay under?
Engineer - Ogden, Utah, US
February 18, 2010
? Are you plating decorative or hard chrome? What is your thickness? Do you use a mist suppressant? Jon Barrows, MSF, EHSSC GOAD Company Independence, Missouri February 2010 A. Mark, Aerospace - Yeovil, Somerset, UK February 2010 |
Q. We plate hard chrome, anywhere from flash chrome to 30 mils build, and we have no mist suppressant.
Mark Robison- Ogden, Utah, US
February 22, 2010
Q. Our iron and copper levels are all under 2 gm/L, mostly under 1 gm/L. From what I have read, these levels should be too low to cause problems, do you agree?
Mark Robison [returning]- Ogden, Utah, US
February 24, 2010
A. Mark,
I certainly wouldn't expect the iron at that level to be a concern. I would be rather more worried about a copper level measurable in g/l, I would normally expect that in the ppm range.
I would consider a dummy plate to reduce the copper levels if I was you.
Saying that, your problem still sounds like a surface cleaning problem or a sulphate:chromic acid imbalance.
February 25, 2010
Allowable Trivalent Chrome in Hard Chrome Solutions
Q. What is the maximum amount (expressed as g/L or % of Chromic Acid concentration) of Trivalent Chrome that can be tolerated in a Hexavalent Hard Chrome plating bath?
Thomas KempSupplier - Cleveland, Ohio
November 22, 2011
A. A large part of that depends on the amount of grief you can tolerate and the level of other impurities. Many people say that a tiny amount is necessary and that may be true. - Navarre, Florida November 22, 2011 A. In some cases, it depends upon the customers specifications. Some specify <2.5 g/L, but I've seen baths with over 7 g/L of trivalent chromium. consultant - Cleveland Heights, Ohio November 23, 2011 |
A. An acquaintance of mine had done a good amount of research on metal contamination in the hard chrome bath. He was able to show that it was the total concentration of cationic metals (iron, trivalent chrome, copper, etc.) that was more important than having unique limits for the different metals individually. According to his study, you want the total contamination not exceed 7.5 g/L. In my own tests which extended his work, I found that limiting the total contamination to no more than 5.0 g/L was a better limit for quality assurance.
GOAD Company
November 28, 2011
Q. Dear sir, I'm new in hard chrome plating.
Can you please tell me that how the impurity zinc enters the chrome bath when our cathode is of mild steel and the anode is of lead?
gurgaon, India
February 10, 2013
A. Hi Rupesh. When you say that the cathode is steel, may be assume that this tank is only used for hard chrome plating of steel components? (I've seen some small job shops use the same chrome plating tank for hard chrome on steel, and decorative copper-nickel-chrome plating of zinc diecastings).
If you can make your posting a bit less abstract you'll probably get more helpful answers. For example, how much zinc contamination? A one-time event or constantly? What tool or evidence are you using to determine that you have a zinc contamination problem? Thanks!
February 10, 2013
July 3, 2013
Q. Hello, I'm working on the Chrome Plating process in a PVC processing company. The bath has high levels of contamination; this is the last analysis that was made:
Chromic Acid: 31,8 %m/v (42,3 oz/gal)
Trivalent Chrome: 1,32 %m/v (1,76 oz/gal)
Hexavalent Chrome: 1,3 %m/v (1,73 oz/gal)
Total Chrome (as Cr): 15,3 %m/v (20,4 oz/gal)
Chloride (Cl-): 4700 mg/L
Cadmium (Cd): 7,1 mg/L
Mercury (Hg): 0,031 mg/L
Arsenic (As): 0,12 mg/L
Lead (Pb): 31 mg/L
We are looking into the purification of this bath and was looking for recommendations.
Thank you for your help.
PVC Company - Coyol, Alajuela, Costa Rica
A. I thought that hexavalent plus trivalent chrome had to equal total chrome in solution.
I think that your chloride is very high. Chloride is about 10 times stronger than sulphate as a catalyst. Unfortunately, it does not remain constant, so is bad.
If you can find one, a porous pot will do a wonderful job of removing trash ions and converting trivalent to hexavalent.
I used Hard Chrome Consultants in Cleveland, OH for mine. I think they went out of business a couple years after Clarence Sr. died.
There a few companies that sell this equipment as an outside of the tank set up, but they were extremely expensive.
October 10, 2019
I have 5000 Litres of chromic acid which is contaminated with copper (4.51 g/l). When this chemical is used we face coverage issues so it's right now stored idly. I do not wish to discard all this chemical so I'd like to know of a way to reduce this contamination. How do I go about it?
Full test report:
Chromic acid: 253.8 g/l
Trivalent chrome: 98.49 g/l
Sulphate: 2.71 g/l
Copper: 4.51 g/l
Iron: 1.46
If anyone detects any other problem in the constituents I'd love to know.
Hard chrome plating - Bangalore, Karnataka, India
