Nickel plating on sand cast aluminum
I want to electroplate nickel on sand casted aluminum articles. what grade of aluminum should I use for no porosity marks & process of best aluminum plating so that results should be as good as on brass?
Atul Bhutani
manufacturer of handicrafts - India
Very little chances of success if you use sand castings no matter what grade of aluminum you choose. I would suggest a permanent metallic injection mold. Much more expensive but almost eliminates problems.
Guillermo Marrufo
Monterrey, NL, Mexico
Dear Mr. Atul,
It is possible to get good nickel plating on sand die-casting. Try combination of HF + HnO3 (20-25% + 75-80%V/V) for etching. Use nickel modified zincating.
K.Ramesh
- Mumbai
