Electroplating of inorganic particles such as diamond dust
Q. I am doing an investigation of plating inorganic particles with an electroplating bath such as copper or nickel. For example, when people put diamond particles in a nickel bath, the diamond particles are plated on the target and are embedded in the nickel matrix. This way, it ends up a surface which is wear resistant.
I wonder if we put TiO2 particles in a nickel or copper both, would the nickel particles get plated on the target and do we see a pure white color plated surface?
Chung W. Ho
thin films - San Jose, Calif.
A. I can't tell you the color or how much TiO2 you can occlude in the deposit, but I doubt that you could get anything resembling white paint; my guess is it would be more metallic looking.
Small amounts of TiO2 are occluded in low embrittlement cadmium deposits, so I'm confident that it is possible to occlude some percentage of TiO2 though. An alkaline bath sounds more promising because acid will dissolve TiO2, I believe.
Q. I want to electrolytically plate Ni with inorganic particles added to change the surface properties of the Ni metal finish. For example, if diamond particles are added, the surface will be more resistant to wear and tear. My question is that if I add TiO2 particles to the Ni solution before plating, will the plated Ni surface have a shining white color or not?
Chung W. Ho [returning]
"Surface Engineering for Enhanced Performance against Wear"
or eBay or
A. I think we are losing something in the translation here. You cannot electrodeposit non-conducting particles onto a nickel surface because the particles do not possess any charge and don't give a monkeys fig whether they go to the anode or cathode. What you are trying to do is called composite plating. The technology has been around for about four decades, but most people have had little success in making it work on a commercial scale unless they bought proprietary systems. This is because the original developers wrapped it up in patents and did not tell the full story. One of the tricks to good composite plating is to use the correct blend of surfactants - anionic, cationic, non-ionic and/or zwitterionic. The trick is to get just enough ionic activity on the particle to help attract it to the cathode. This can be coupled with adequate agitation and/or allowing the particles to gently "fall" from suspension onto the workpiece. the particles are then surrounded by the depositing metal and become trapped, a bit like something falling into a swamp. You will not be able to get a paint-like finish to the surface because the particles are trapped in a matrix of metal and will therefore be discontinuous. I would suggest you spend some time reading the patents and a couple of text books on composite plating technology - they should give you further guidance.
Q. Comparison of the following categories in terms of market share and expected growth:
- Electro- vs electroless plating of composites,
- Metal types (Nickel, Gold, ..) used for the composites,
- Filler used for the composites (Boron Nitride, Silicon Carbide, PTFE, Nanodiamonds, other),
- Applications of composites and main filler per application,
- Drivers for growth of the composite plating segment, e.g., substitution of Chrome (VI) plating in specific applications?
- Cost breakdown of composite plating and differences in costs of fillers?
Sheshank Reddy
Analyst - Hyderabad,Telangana, India
"Electroless Plating"
by Mallory & Hajdu
or eBay or
A. Hi cousin Sheshank. You haven't yet introduced yourself, nor included a verb in your paragraph, but I'm guessing you are trying to develop a saleable market report on composite plating, as opposed to writing a thesis or public article on the subject? It sounds like a good topic, but I doubt that you can expect much information from a public forum except for an occasional piece of anecdotal data like "We prefer electrolytic to electroless because ...", or "We moved from diamonds to boron nitride because ..."
Chapter 11 in "Electroless Plating" by Mallory & Hajdu.
is "Composite Electroless Plating" by Nathan Feldstein of Surface Technology in Robbinsville NJ. Companies like Surface Technology have specialized in offering licensed and patented processes for composite plating for many decades and can presumably supply volumes of such data, but might have problems with offering it for free :-)
pic of Ted Mooney
November 2015
Q. Hello sir, thank you for your reply. I am sorry for not introducing myself, in my first question. I am a market research analyst, trying to make a report on the composite metal finishing one.
I would like to know which type of composite coating is mainly used now -- electroless or electroplating, and which out of these two would have a good future, based on your point of view.
Thanks a lot for your reply in advance
Sheshank Shivampeta [returning]
November 14, 2015
A. Hi again. I don't personally have any actual data to make such a prediction, although I hope other readers will. But while we're waiting for them, my guess is that electroless has the brighter future. My principal reason for leaning that way is simply that the principal advantage of electroplating over electroless plating -- much lower cost -- tends to fade away when dealing with the complications of composite plating; it's not inexpensive with either technology :-)
pic of Ted Mooney
November 2015
A. Lots diamond tool bits (such as dental) sold in the market were plated through nickel electroforming process.
Weilong Tang
- Toronto, Ontario, Canada
November 19, 2015
A. Hello,
The only hands-on experience we have with composite plating is diamond files which we regularly use. Best ones (german brand) are plated with a chrome binder. It may be a matter of better processing procedures but they easily outlast those made with nickel binder (electro or electro less?).
Best regards,
Guillermo (Bill) Marrufo
Mold Finish Mexico
Guillermo Marrufo
Mold Finish - Monterrey, Mexico
November 27, 2015
A. Thousands of grinding wheels are faced with electroplated nickel containing small diamonds which are "trapped" in the nickel.
For some wheels which use large diamonds, the diamonds are individually glued to the substrate, then plated with a heavy nickel layer to trap and hold them.
