Letter 42079
Glass in anodising process [UK]
August 30, 2006
Hi,
I'm doing some cosmetic trials on anodising bead blasted aluminum and was wondering if there are any risks to the performance of our anodising line due to contamination from the glass.
John Peacey
- Gloucester, UK
August 31, 2006
I can not think of any thing other than if you use a flouride in your line, it might be consumed slightly faster. Most of any of the broken beads that are stuck in the aluminum will come off during the caustic etch step.
- FL
September 1, 2006
Elaborating on Watt's correct answer, glass dust, glass particles, and all the contamination that is in/on the glass will imbed in the soft aluminum - therefore you MUST heavily etch to undercut the imbedded junk. The glass must not have been used on any other metal. The glass will not contaminate the anodizing solution, it will fall to the bottom, however, under some conditions of solution agitation the glass dust will "occlude" in the anodizing coating.
Work was done at NASA Huntsville in the 1960's which occluded diamond dust into hard coat anodic films.
Garner, NC, USA
Editor's note:
   Mr. Probert is the
   author of
Aluminum How-To
Dear Reader: please choose what you want to do--
I want to answer or follow-up on this subject publicly (in non-commercial fashion).
My company is a supporting advertiser at finishing.com and we want the contact information to reach the inquirer privately.
I want to post a new question or inquiry of my own on a different subject.
