Letter 42047
How do you use hydrochloric acid to clean brick paving without doing damage to bricks and garden [Australia]
August 28, 2006
I want to clean a large area of brick paving and was told to use hydrocloric acid, the label has fallen off bottle and I need to know how much to mix with water to use it safely to the bricks, garden and any pets around?
Jean Leach
householder - Perth , Western Australia
August 28, 2006
This is a hazardous material and should not be applied on a whim or unless you know exactly why you're doing it. It is NOT a cleaner and is not for cleaning brick; it is a destroyer of concrete and mortar and the reason it is used is to dissolve mortar stains from brick. If you have no label you don't know the starting concentration, Jean, so any talk of dilution ratio is meaningless. Take the bottle to a hazardous wate disposal facility, and buy a fresh one if you insist on using hydrochloric acid -- it's inexpensive stuff, but will kill your plants and certainly burn your pets if they are exposed to it. Good luck!
finishing.com Inc. - Brick, NJ
Dear Reader: please choose what you want to do--
I want to answer or follow-up on this subject publicly (in non-commercial fashion).
My company is a supporting advertiser at finishing.com and we want the contact information to reach the inquirer privately.
I want to post a new question or inquiry of my own on a different subject.
