Letter 42046
Achieving uniform plating thickness in bores/ ID of cylindrical shaped components [India]
August 27, 2006
Dear All,
I have been worrying offlate with my zinc plating on a component (pulley) which is not getting a 6 micron plating thickness at the ID bore. As of now i am holding the component in that bore only with a jig with a pvc coating . where do u see the problem is ? Also i am unable to achieve the Salt spray test requirements as well. I am wandering what process/ bath parameters will actually regulate the plating quality in terms of pinholes, porosity, pitting, Salt spray life . please suggest your recommenations.
Kalyan kumar Thekuru
Quality manager - Mumbai, Maharastra, India
August 28, 2006
Electroplating does not give uniform plating thickness, Kalyan. The best you can hope for is "good enough" uniformity. Please sketch your racking situation because I cannot undertand what you are saying. Whole books have been written on zinc plating, so it is hard to describe the most critical aspects, but please tell us your parameters and hopefully you'll receive comments if they seem irregular.
finishing.com Inc. - Brick, NJ
Dear Reader: please choose what you want to do--
I want to answer or follow-up on this subject publicly (in non-commercial fashion).
My company is a supporting advertiser at finishing.com and we want the contact information to reach the inquirer privately.
I want to post a new question or inquiry of my own on a different subject.
