Letter 42035
Bubble chrome structure [Holland]
August 27, 2006
After sandblasting Cu-surface (before blasting mirror polished: Rz below 0.2µ) after blasting Rz is between 1.1-1,3µ.
My aim is that roughness will not change by Chrome plating (appr 30µ), but that structure will change from sharp till rounded bubble structure
I succeeded on small scale: roll diameter 210mm, but I failed until now on bigger scale: 900mm Who can tell me what is cause, and how to investigate differences
as chrome process, I use HEFF25, current density of 30-50 A/dm2, plating time of 90 min
Frans Brock
client of industrial plating shop - Oosterhout, Holland
September 3, 2006
You are experiencing geometrical levelling that comes with thickness. You may need dull satin copper deposit instead of a bright one that will give you a rougher surface before chrome plating.
regards,
Rudolf Kempf
- Haan, Germany
Dear Reader: please choose what you want to do--
I want to answer or follow-up on this subject publicly (in non-commercial fashion).
My company is a supporting advertiser at finishing.com and we want the contact information to reach the inquirer privately.
I want to post a new question or inquiry of my own on a different subject.
