![]() (Cycles thru suppliers) |
Letter 42034 Black Oxide on stainless finish WITHOUT sulfur [California]August 25, 2006 My company currently uses black chromium plated stainless (type
304 and 316) parts for experiments, but would like to replace this
with a less expensive and more robust black oxide process. The
blackening is for optical absorption, such as laser dumps, laser
baffles, and spectrometer view backgrounds. The parts are in a
ultra-high vacuum and often get up to 350 deg C. The problem is that
tests have shown that the black oxide parts contain traces of sulfur
that "outgas" in the vacuum and sulfur is extremely problematic to
our experiments. It seems that the "activators" that are used prior
to the blackening salts use sodium bisulfate. Is there a black oxide
process for stainless steel that is sulfur free? What happens if the
activator is not used prior to using the salts? Doug Taussig
Dear Reader: please choose what you want to do--
Save
