Letter 42031
Dipping Paint
[Indonesia]
August 28, 2006
I am an engineer in Paint process for Disc Brake on Honda
Motorcycle
And now we in progess on developing Paint Disc, with Dipping Paint
process.
We have tried with usual Dipping process but not good enough
result.
May I have some share about how the dipping paint process really need
and do.
How the detail. and what paint should i take. also what process
should i trough.
please share on me
thanks,
Andhika
- Cibitung, West Java, Indonesia
August 28, 2006
I think your question is too broad for us to be able to help you
very much via an internet posting, Andhika, but we'll see.. Maybe
start with the excellent book
"Industrial Painting" by
Roobol?
finishing.com
Brick, New Jersey
August 31, 2006
I am not sure what kind of products you are manufacturing. But for
a dip paint you need to have a good phosphating layer of 2 -3
microns. Maintain the viscosity of the bath depending on the
thickness you need to achieve.
Wishes.
Aurobind Venkataraman
Mekins - Hyderabad, Andhra Pradesh, India
October 3, 2006
Dear Andhika
Sorry but I have only just seen your question - was your problem
solved?
I presume you wish to coat the the metal on the brake pad fitting -
if so I used to supply (some 25 years ago) a dipping black to about
80% of the UK brake lining mf's.
This was a solvent based stoving epoxy as it had to have resistance
to the brake fluid.
However, with current technology I would guess you could obtain a
similar product but using waterborne technology.
Should you require further info do not hesitate to ask.
Dear Reader: please choose what you want to do--
- I want to answer or follow-up on this subject
publicly (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- I want to post a new
question or inquiry of my own on
a different subject.
