Electroless nickel plating in a KOH environment
Q. I have some parts that need to be plated. I have been investigating the best way to do this. Are there any issues with electroless nickel plating in a KOH environment? I have some concerns with phosphorus being used in the electroless process. Will this be an issue in the long run? Thanks for the help in advance.
Marc Higginbotham
Materials Technician - Michigan
A. Exactly what are your concerns with phosphorous? Remember that there is zero metallic (elemental) phosphorous involved.
KOH should not be a problem to the EN, but you really need to include mechanical abuse, base metal, concentration, temperature and exposure time for a better answer.
A. KOH will attack electroless nickel.
A. A low phosphorous EN can withstand alkaline environment. HIGH PHOSPHOR and mid cannot!
sara michaeli
sara michaeli signature
Sara Michaeli
Tel-Aviv-Yafo, Israel
thumbs up signThank you for all of the responses. I chose to go with a sulfamate nickel coating. Thanks again.
Marc Higginbotham
