Remove ammonia from electroplating nickel
My problem is that my electroplating nickel has been contaminated with Electroless Nickel.
Any of you know how to remove it from the electroplating nickel?
I have tried at laboratory with high pH, KMnO4, "natrium hypochloride", iron sulfur. None of them has work.
Simao Sabrosa
Galvametao - Brazil
Hi There,
how do you determine the ammonium contamination? Maybe you should try a dummy plating with higher voltage.
Dominik Michalek
- Mexico City, Mexico
Its probably easier to dump the bath and start again. Oxidising ammonia [on eBay or Amazon (adv.)] to nitrogen is not easy and will probably put everything else out of specification. Oxidising ammonia to anything else will only result in more problems.
Ammonia is not removable from a nickel bath. Try to cut the bath to an acceptable level.
Russell Richter
- Danbury, Connecticut, USA
