Finish that can be applied to a plastic surface to make it inert
Is there some sort of finish that can be applied to a plastic surface to make said surface inert...seal against bleed through of possible chemical residues?
I want to purchase high density polyethylene large diameter pipe (2" thick and 28" diameter) recycled from a copper mine. It will possibly have had sulfuric acid pumped through it and possibly metal salts in solution. I want to grind out 1/8 to 1/4 inch of material from the inner surface and apply a chemically inert surface to trap any small amounts of materials possibly left behind. This resurface should not off-gas or be toxic in anyway.
Thank you for any suggestions you can give.
James W. Williams
James Wade Williams, P.C. - Mesa, Arizona
Whatever you sealed it with, if you could perfectly seal it, could eventually erode or corrode away, releasing whatever it was that was sealed in.
If this is a critical application, forget it. But if it's merely your reasonable expectation that the pipe not contaminate anything, then washing it thoroughly, removing a 1/4 inch, visually inspecting for cracks, washing again, and testing for contaminants sounds workable if the pipe hasn't been badly abused to where it might have cracks running deep into it.
