Hot rolled steel floor for home. Q&A, Problems & Solutions
Intro / synopsis: Hot rolled steel (or cold rolled) can be used as flooring in a home as shown on the Debbie Travis show on HGTV back in 2006. This discussion covers how to clean, seal and wax it, how to deal with the joints, and some nice successes with the approach in the years since.
Q. @S. fisher: I am interested in rolled steel for my stairs. Will you please share the process and perhaps a photo of how your steel stairs worked out?
R Johnson- San Diego, California
March 14, 2022
Ed. note: Hi R. We'll try to pass your message on to S. -- but few people even maintain the same e-mail address over the years. Luck & Regards.
Q. I've just installed hot rolled steel in my home as flooring. I was wondering if there exists a product that will seal the steel without causing it to lose its natural color. Keep in mind that the steel is already installed in a home so a product that is not very noxious would be great.
Mark Sawczukdesigner - Fort Lee, New Jersey
! Please send a picture, Mark, I've never personally heard of such a thing and wouldn't have guessed that it would be successful, but apparently people know yet another thing I haven't learned yet :-)
A. I believe that if you had it thick enough it would work out rather well (provided you don't mind those cold feet mornings).
I am sorry to say that you are probably out of luck for keeping the "natural" look of the steel without it rusting. Hot rolled black steel generally has surface oxidation from the rolling process. The cheapest and best solution to your problem I can think of that will protect one side of your flooring would be wax, lots of wax. Somewhere between 3-5 coats would probably work. This will probably be a high maintenance floor.
As Ted said, could we see the floor?
blacksmith - Shawboro, North Carolina
Q. I saw a show on HGTV where Debbie Travis installed hot rolled steel floors in her own home. I have been trying to locate a company where I can buy them for my own home as well and came across your posting. I believe she sealed the floors with bees wax [on eBay or Amazon (adv.)] . She just polished it on with a clean cloth. I have been trying to find the show details online and have been unsuccessful. If you have any info on the installation of these floors it would be much appreciated. Good luck!
Melissa Gremich- San Jose, California, USA
A. I saw the Debbie Travis show repeated today and she sealed her floors with a combination of Murphy's Oil Soap [on eBay or Amazon (adv.)] and bees wax [on eBay or Amazon (adv.)] . I, too, would love to know who manufactures and installs these floors if anyone knows!
Maureen Laird- Salt Lake City, Utah, USA
A. Here's a link to Debbie Travis's episode with the steel floors.
www.painted-house.com/episodes/12/160/?view=all ⇩
This unconventional floor is new to this country but is rapidly gaining popularity in Europe.
We bought 4'x4' sheets of hot rolled steel. This is the type of steel used in general construction. It is dark grey in colour and has beautiful tones of blue running through it. We purchased the metal from a metal 'supermarket'. These are companies that sell industrial metal in any quantities. They are all over the country.
The existing floor must be completely flat (preferably new plywood). Because the steel is glued in place you cannot have a heated floor. Once down the floor is secured with small weights that are removed after a couple of days when the glue has dried. The metal floor must be sealed or it will rust. We washed it down with soap and water and then with carnauba wax [on eBay or Amazon (adv.)] . It was then sealed with a mineral wax. The floor is warm on the feet as the metal takes on the temperature of the room."
I too would like to know how to seal where each sheet butts up against the next one. I don't want water getting through to the floor. Any suggestions would be greatly appreciated!
T lavery- Sacramento, California, USA
[Ed. note: The above link broke -- don't go there. Thankfully, Archive.org's wonderful Wayback Machine saved a copy for us
These days information often simply disappears forever. If that bothers you please consider a donation to The Internet Archive.]
A. I saw this episode also while I was looking for a non-conventional flooring alternative. After contacting a local steel company and discussing it with them, I am going with a 16 gauge cold-rolled sheet.
16 gauge is about 1/16 inch thick and weighs 2.5 lbs per square foot. They come in 4' X 8' (4' X 4' was used in the episode) but can be cut at the mill. The difference is that cold-rolled has an improved surface finish (mill scale is removed-but you may want the mill scale) and is usually more squared and has better thickness tolerances.
I would recommend going to a local steel-mill and getting a sheet of both. That way you can clean and test different wax solutions to get an idea of the finished product.
They also have colored wax that would look great in the seams. But try different ideas to get what you want.
I am going to try the beeswax [on
Amazon (adv.)]
- Boston, Massachusetts USA
A. Hot Rolled Steel can be purchased from just about any local metal shop, someone that sells structural steel, iron bars, general metal for construction, etc. I found that if I typed 'hot rolled steel' and my local area (Toronto or Ontario) I came up with numerous suppliers.
Q. What I would like to know is: if you use this as flooring how do you keep water from going between the cracks between the sheets, and then rotting or forming mold?
Also, what would be the best way to affix it to a concrete floor, other than using screws? Kevin Hedley
- Toronto, Ontario, Canada
A. What about J B Weld? They have a marine application [adv: JB Weld Marine on eBay or Amazon (adv.)] that looks like it would be perfect!
A. I installed steel floors in my home over 2 years ago. I used cold rolled steel, it is about 1/8" thick and they are in 5' x 8' sheets ... yeah, super heavy! I used an adhesive that bonds metal to concrete on the underside. Eventually I ended up welding all of the joints. To top it off, I have a sunken living room, so the steel for the stairs is bent and seamless. I also have steel stairs from my first to second story of my home.
When you first get the steel down on the floor, you will need to use Murphy's Oil Soap [on
Amazon (adv.)]
and a light amount of water. This process is very nasty, but it will get all of the black gunk off the surface of the steel and it will end up very clean to the touch. Then, simply apply a thin layer of automotive wax and buff off. I ended up buying an Oreck buffer to apply and remove the wax. Makes it very easy. I do this about every 2-4 weeks. I am pretty happy with final product. You do have to be careful with certain substances staining the steel though.
- Tulsa, Oklahoma
March 1, 2008
Q. I am curious as to how you welded/soldered the metal. What kind of torch and solder? I wonder how hot it got and did it affect the sub floor?
Thanks, Lise
- Santa Rosa, California
March 26, 2012
Q. I bought a house from an architect who installed rolled steel tiles in the front entry. They continue into the powder room. Tiles in the powder room were powder coated prior to installation. They look great. He planned on the front entry to show a bit of wear prior to taking them up for powder coating, which is quite an endeavor. All tiles are screwed down in each corner, so they can be removed. However, I'm more interested in cleaning and coating them. Hence this forum.
Q1: How did the car wax work?
Q2: How did the beeswax work?
BTW - the link to Debbie Travis shows on HGTV no longer works, and her site is not helpful. Thank you for those that answer.
- Langley,Washington USA
April 30, 2018
Ed. note: Hi David. T Lavery has excerpted the relevant paragraphs from the website for us above.
