Fluoride analysis in HF/Nitric (etch for titanium)
Q. I have to calculate/ check concentration of HF and nitric acid from the solution. How can I check?
Can you guide me with testing method and with formulae?
- Mumbai, India
January 30, 2023
A. Hi Shakilahmad
We appended your inquiry to a thread which answers it, and it seems that an ion-specific electrode for HF is the best way to start, but for additional options you can search the site with the term "analyze HF Nitric"; we have at least a half dozen other threads on the subject if you don't like the initial answers you read :-)
Q. My company uses a 10% HF acid solution for several glass polishing and cleaning processes. I am searching for the best method to use to monitor the status of the acid solution. At one time we had a very routine schedule of use and replacement but now a higher demand has been placed on some of the cleaning processes. Therefore, I would like to be able to maximize our productivity while maintaining the integrity of the solution.
We have many analytical tools available but I would like to have some outside input before trying anything.
Would an ISE method be best? Should I try to monitor the silica content?
Aaron Joseph O'Connor- Urbana, Illinois, USA
A. Go with the ISE. Most of the folks I know with HF Nitric pickles use this method.
Martin Trigg-Hogarth
surface treatment shop - Stroud, Glos, England
? Does the Ion Selective Electrode method correlate with etch rates of the solution? The glass dissolving into the solution may interfere with the etch, and the fluoride content may not be the best may to control the solution. How about titrating with caustic to get an acid content, and determining the weight loss of a piece of glass for estimating the etching capability?
Tom,
I think you are right here. Let's go for the simple but right answer. Etch rate testing would be the best control as you are testing the function you wish to control. Also it is cheaper!
Q. We have a nitric/HF titanium stripping tank. Last week we requested an addition of HF and although the concentration of the HF increased, so did the concentration of the nitric acid, however no nitric acid was added to the tank. What would account for this increase in concentration?
We are using a titration method that includes titrating with ferrous sulphate ferrous sulphate
[affil links] (~0.3N). We are also curious to know how long ferrous sulphate ferrous sulphate
[affil links] can last sitting in an amber bottle on the bench?
- Winnipeg, Manitoba, Canada
A. First, can you verify that the tank was at the exact liquid level as the last time the analysis sample was taken. If it was, then your analysis is off. Your test method is subject to an operator influence, even when it is the same chemist or technician. Temperature is the largest offender in this analysis. Next, the titrant can be added too fast and you get very tiny red brown specks floating around that you have to wait for them to dissolve. This is one of the least precise volumetric analysis that I ever came across. Try it on three samples from the same original grab sample. I think that you will be shocked at the variance. I gave up and went to a selective ion electrode. Do a search at this site. It has been discussed several times. My feeling is the titrant should also be stored in a dark cabinet. I had to restandardize it every month to meet the customers requirements for QC.
James Watts- Navarre, Florida
A. I think Mr. Watts thought that your question pertained to the fluoride titration. I use a different method for titrating nitric acid that I like much better. Since nitric acid is a stong acid and HF is a weak acid, it is possible to use sodium hydroxide to titrate nitric without titrating the HF. The trick is to end the titration at a pH that is low enough where no HF interferes. You will find that if you purchase ethyl violet indicator which has a very pretty endpoint at pH~2.4 (or just use a pH meter) that no HF interferes. At this pH, you have not yet neutralized all of the nitric, so you will need to make a set of standards and establish an experimental factor. Also spike some HF at various concentrations to prove to yourself that it does not interfere. Getting all of this done takes a little work, but I think that your results will be much better.
Jon Barrows, MSF, EHSSC
GOAD Company
Independence, Missouri
A. Each to his own. The HF is the important portion of the analysis and the nitric is vastly less important. If you titrate the nitric and have a =/- 2% and titrate total acid (or a continued titration) with a =/- 2% , it is possible to equal most of the HF concentration if you miss in opposite directions. The specific ion electrode was repeatable to under 1% of the total HF, regardless of how I did it. Since this is the important component, I strongly preferred it to the standard procedure for analysis of 3 major turbine engine manufacturers.
Now back to the original question. Their analysis (the recommended one)used a weak procedure. HF is not a weak acid by the definition that I remember from chemistry. However,it very easily can have an inflection point at a different pH than the nitric and still be a strong acid. Your procedure is faster, as it would have to be to protect a pH electrode from the fluoride attack.
A. Both respondents are correct but to answer the original question, I think you will find that the reason that the nitrate went up was because the titrant was not re-standardised. ferrous sulphate ferrous sulphate
[affil links] oxidises in air quite easily and requires regular standardisation. Suggest you standardise against a nitrate solution so that you standardise your analysis method at the same time as standardising your ferrous solution.
One technique I have used to minimise this oxidation is to store the titrant in a flexible polythene container and expel the air by squeezing the bottle to expel air and then putting on a tight cap. I don't think the brown bottle has any effect.
Then add a few bits of iron powder to reduce the oxidised iron-- but you have to standardise regularly
Geoffrey Whitelaw
- Port Melbourne, Australia
A. I was not disagreeing with Mr. Watts that HF should be determined by ISE, nor do I disagree that the HF is the most important component. I was offering an alternative analysis for nitric acid that seemed to me to be Jennifer's difficulty. As far as HF being a weak acid, it is weak by definition that it is not fully dissociated in water into H+ anf F-. It exists partially as molecular HF in equilibrium. The equilibrium constant for HF is 6.8x10-4. This puts it between formic acid and acetic acid [on eBay or Amazon (adv.)] on a list of common weak acids. Nitric, on the other hand is a strong acid meaning that it is fully dissociated in water into H+ and NO3-. It is this property that would allow for titration of the strong acid, at least partially, before the weak acid interferes. Because you can only titrate it partially by itself without titrating the mix, I was recommending that she establish an experimental factor. It would not be nearly so simple a matter to account for the HF using caustic, so ISE would be the way to go as I share a dislike for the standard alizarin method. I hope this clarifies things rather than making them more muddy.
GOAD Company
Q. I appreciate these answers, however at this point purchasing an ISE is out of the question, and I would like to learn more about the analysis requiring the ethyl violet indicator. I did fail to mention that we use 5mL of 5%v/v HNO3 in our blanks. I do obtain repeatability when titrating with the ferrous sulphate ferrous sulphate [affil links] when using the 5 mL of 5%v/v HNO3 in the sulfuric acid solvent. So, repeatability is not an issue. In fact, I took Mr. Watts advice and did 3 different titrations from the same sample and received comparable results. However, I am still uncertain as to why the nitric acid increased without an addition of nitric acid.
Jennifer Mackey [returning]- Winnipeg, Manitoba, Canada
A. Perhaps there is a simpler explanation to the anomaly of the levels. When the operator made the addition care was not taken in properly mixing the bath, so then upon collecting a sample the concentrations were for a lack of better terms out of whack after the analysis. Have the operator make another addition since the HF concentration has dropped by now, and emphasize the importance of mixing before collecting a sample. I'm certain this will provide you with a better idea of the true concentration of your nitric-HF bath.
Derrick Kasunic- Winnipeg, Manitoba, Canada
A. Sampling is also a source of problems. I used a home built "colwissa" to sample the tanks from several different places and depths. I would not accept samples from the plating/cleaning folks because they were prone to NOT make sure that the tank was at the proper liquid level and stirred, as well as just dipping a beaker into the top 2 inches at the front of the tank. Congratulations on getting repeatable analyses. As to the original question, It is an absolute impossibility as stated. Not having a representative sample of the entire tank is the strongest probability. A properly mixed tank makes it a lot easier to get a representative sample.
HF analysis using ISE
Q. My company is currently trying to switch to the ISE Fluoride analysis for our HF/HNO3 To milling tanks. The ISE electrode will calibrate fine using a three point calibration with NaF standards, but I am have trouble with the sample measurement drifting significantly (+ 50 ppm F) over e period of 1 hr. I'm in contact with the electrode manufacturer, but they can't seem to determine a reason either. (Note: the sample is buffered with TISAB III) My question(s) for all of you that use the ISE for fluoride analysis in this type of solution: how do you accurately determine the F of these samples with such a large drift? Or do you even see a drift? Is this a matrix interference? Any suggestions on how to reduce this?
Elaina L [last name deleted for privacy by Editor]Aerospace Industry - Terre Haute, Indiana, USA
A. Part of that will depend on which technology electrode that you are using. A conventional electrode will drift and should not be left in the sample any longer than it takes for the mV to drop to a point that it reverses and starts climbing. That will give you a very repeatable analyses. Use the valley reading. The standard and the sample also have to be diluted to a region where the TISAB can swamp out the background noises. Also needs to be in a linear range. I forget which TISAB I used, but it also made a difference.
A. What is the pH of your sample with TISAB? If below 4 pH the species in solution is a HF complex and not free fluoride ions. ISE's only can measure free Fluoride ions. HF is used to complex iron among other things forming fluoride complexes. Why are you doing the measurement? To see if available fluoride is still there for complexing or other? Adding TISAB typically is for samples where the pH needs to be brought down so hydroxyl ions do not interfere. With Nitric and Hydrofluoric ions around I don't think that's the issue. Are you diluting your sample with water? Why are you trying to make this measurement?
Burdick,Janeinstrumentation - Woonsocket, RI, USA
A. Use of ISE for HF is OK if there are no interferents such as iron. I analyse HF in pickling tanks and need to remove Fe, Cr, Mo as interferents by using a complexing agent. I hope this helps.
Paul Gillespie- Melbourne, Victoria, Australia
Q. Hi there
I know that many postings have been made on similar topics, I just wanted to express my problems in measuring this type of solution.
We test titanium etch tanks belonging to a leading aero manufacturer, who use tanks around 2-5% HF and about 20% HNO3.
Current methods used include:
- direct measurement with standardised fluoride ISE, which is fairly time consuming and not really stable;
- indirect method by measuring nitrate by IC and subtracting from total acidity. This involves a large dilution, which adds error, and is also very time consuming.
We are testing a new method which involves titration against lanthanum nitrate, which we obtained from Eutech. This works well for the standard, but unfortunately we can't get an end point for our samples!
I theorise that, instead of being in solution, the unreacted HF exists as a complex with titanium fluoride:
6HF + 2Ti -> 2TiF3 + ^3H2
3HF + TiF3 -> H3[TiF6]
As a result no amount of TISAB will free this fluoride from the complex. To liberate the fluoride from this complex I think you would need to use something more nucleophilic than fluoride (i.e., nothing!) or an ion chromatograph might be powerful enough.
I think the problem may be the definition of free fluoride....
Nottingham, UK
A. What I do is time consuming, but works. I use the method of additions, plotting apparent concentration vs. spiked concentrations. I evaluate the apparent concentrations by making a four point standard curve with a standard fluoride solution, the points being 50, 100, 200, and 400 ppm. The samples, of course, must be diluted down into this range. Dave Wichern Consultant - The Bronx, New York A. You do not want to analyze any of the complexed fluoride. The only fluoride that does the work in your tank is the free fluoride. Navarre, Florida |
A. I agree that what we want to measure is "free" or active fluoride. After all, the total fluoride hardly changes as titanium is etched, but the etch rate certainly decreases!My samples typically contain ca. 20 g/l free fluoride, and I use the simple method of diluting the sample 1:100 in 30 g/l NaOAc. Then I use ISE to measure the mv. Standards are made to bracket the unknown, and the rest is quite simple. The addition of ABF to raise the fluoride so as to show approx. 20 g/l in the bath always restores the etch rate to the nominal value, which in our case is approx. 3 mil/hr at ambient temps.
Mac McNeil- Elmwood Park, NJ USA
July 29, 2008
Q. Finding concentration of Hydrofluoric acid and sulfuric acid from a mixture I have received a sample of an acid mixture, I would like know a method by which I could determine the approximate concentration of both hydrofluoric acid and sulfuric acid.
Reema GMicrobiologist - Mumbai, Maharashtra, India
I've been working on trying to obtain a split of the HF and nitric acid compositions for our acid pickling baths (titanium and stainless steel).The method I've been using is obtaining a total free acid value of both acids by titration with 1M NaOH [1N NaOH on
Amazon (adv.)]
and then following this up with a second titration using an Fluoride electrode and reference electrode and Lanthanum nitrate as a titrant. The titrator we use then takes the fluoride value off the total free acid value to give us the Nitric value. We've had success only a few times when tanks are quite fresh, however once contamination level build up its very difficult as no end point on the second titration is picked up.
Recently my attention has been drawn to the Millivolt/concentration calibration curve method; using standard solutions of HF to obtain a range of MilliVolt readings. I've also notices that when I start the second titration the mv reading on our titrator is a negative reading; my questions are therefore is this negative reading due to free fluoride ions in solution and if so will this change on varying levels of HF? If this is so can I just use this initial millivolt reading without doing a second titration to obtained a relatively accurate reading of HF; by using a range of these initial millivolt readings of HF to obtain a calibration curve similar to that mentioned above?
Any help would be much appreciated as I'm a non-chemist.
James
- Nottingham, UK
September 12, 2011
A. Tough problem! I've wrestled with it myself. Approached it three different ways:
1) Did total acidity via titration with NaOH; determined HNO3 conc. via titration with FeSO4 in chilled conc. H2SO4. Determined HF, HNO3 concentrations by arithmetic.
2) Did total acidity via titration with NaOH; determined F- concentration via electrode using the method of additions (the math gave me a headache, but it is possible) then determined HF, HNO3 concentrations by arithmetic.
3) Did total acidity via titration with NaOH; tried to do what you did; La(NO3)3 titration with electrode as endpoint.
Results: (1) and (2) gave totally different results. No useful endpoint observed with (3)
If I wanted a (4), I'd propose determining F via a distillation procedure. Then, there would be a third answer, likely different from the first two. Closer to (2) than (1), probably.
What's the "right" answer? HA!
My conclusion: what are we trying to measure? Once the bath is put in service, the HF starts to break down; the F is present as transition metal complexes with Fe and Ti. It is now less effective as an etchant...it's "unfree" HF.
My suggestion: think up an empirical test on samples that are as similar to the actual work as possible (if practical, use real work pieces) and do some kind of test to see how effective the bath is at doing what you want it to do. Cut the sample of the bath that is up on the line with fresh HF, and/or fresh HNO3, and do the same test on these solutions. (Watch phantom variables, like temperature; try to replicate process conditions)
Now, do your lab tests on your line bath; and, on your lab concoctions. Look for a correlation. Find one. Now you have your test.
Sound like a lot of work? It is. But if you follow through you'll solve the problem.
My motto: Science is a business of empiricism.
Dave Wichern
A. We've been working with thermometric titrimetry for the analysis of various acid mixtures, and have some rational approaches to the analysis of etching solutions containing nitric and hydrofluoric acids. (DISCLAIMER: I work with Metrohm International). In the following, the analyses were performed using a fluoride-resistant thermometric probe (really just a highly responsive, very sensitive thermometer). The analyses are genuine titrations, not calorimetric, and use the probe merely as an endpoint indicator. Endpoints are determined by the rate of change of temperature, not the actual solution temperature.
Some examples:
1. Analysis of HNO3, HF: HNO3 and HF are determined in a non-aqueous polar solvent, with aqueous 2 mol/L NaOH as titrant. HNO3 and HF are differentiated by an inflection in the temperature curve (due to differences in the heats of formation of HNO3 and HF).
2. Free HF can also be determined independently by a direct titration with Al(3+). The solution is strongly buffered with an acetate buffer composed of NaAc, KAc and HAc. The buffer also provides the excess of Na(+) and K(+) necessary for the exothermic reaction:
6F(-) + Al(3+) + Na(+) + 2K(+) -> NaK2AlF6
This yields precise results, with % rsd's <0.2%
Best regards
Tom
- Brisbane, Queensland, Australia
April 3, 2013
Q. So I'm just a lowly chemical technician who etches titanium in the HF/HNO3 solution this thread is talking about. I've read through this and I have a few questions that hopefully somebody might be interested in answering.
I think our lab probably does the electrode thing to determine fluoride content. And then what I'm hoping is to use this number to figure out what percent of the total acidity comes from HF and what comes from HNO3 so I can figure out how much of each is in there.
What I'm worried about is does the electrode only measure free fluoride? If so wouldn't simply measuring the free fluoride really be off from how much acidity came from the HF? The H+'s from HF would all still be there while a lot of the fluoride would be complexed with the titanium we've dissolved? So if I only look at free fluoride I'm going to attribute more of the H+'s to nitric acid than is actually the case?
What if I precipitate out the titanium by raising the pH of the solution? Won't I free up all the fluorides again so I can measure how much HF has actually been added over the weeks and have a better idea of what total acidity should be attributed to it?
Can I ask about using FeSO4 and H2SO4 to figure out HNO3 concentration too? I'd like to do multiple methods so I can see if I get the same results with each. I'm guessing maybe iron and the NO3's form a compound that precipitates out or something?
Any help anyone can give me would help me figure out how to solve my problem a lot faster. Thanks in advance.
- Albany NY USA
February 16, 2014
