Remove solder from silver dollars
Q. I have a few silver dollars that someone made into a bolo tie. I have gotten the dollars loose from the tie back but now need to remove the metal or glue that was used to hold them together.
Donald Benjamin
retired business owner - Missouri
1923 Silver Dollars on eBay
A. If it was solder, you can go into any RadioShack and ask them for the proper tools to remove it. If I recall, it just takes a soldering tool and some special tape like stuff - fairly inexpensive.
If it was glue, I've got no idea... but try searching the archived letters, you might find a hint or two.
Jim Gorsich
Compton, California, USA
A. Hi.
Yes, you can very easily remove 98% or more of the solder with a cheap electric soldering iron [on eBay or Amazon (adv.)] and very inexpensive "solder wick" [on eBay or Amazon (adv.)] -- $10 or $15 will cover both. Whether you can get 100%, absolutely no remnants or wetting left, I'm not expert enough to know :-(
As for glue, any solvent you try is quite unlikely to damage metal; they dissolve organics like paint and glue.
