Electroless Nickel Plating for wet sour service
Q. @ NAVED MAHDI: SO HAVE YOU USED ENP COATED BALL VALVES IN SOUR SERVICE? CLIENT ACCEPTED? DID YOU FACE ANY ISSUE? AS WE ALSO WANT TO USE ENP COATED BALL VALVE FOR SOUR SERVICE. APPRECIATE YOUR REPLY.
AAD DANI- Singapore
June 2, 2022
Please, We would like to know about the updated ELECTROLESS NICKEL COATINGS and its applications repairing equipment' surfaces in the oil and gas industry. We will appreciate your help. Regards.
PETROLEOS DE VENEZUELA (PDVSA) - Venezuela
1995
by Sha, Wu, & Keong
A. Hi, Dany. Thanks for visiting. References you might consider are:
Chemical (Electroless) Nickel Plating by G.G. Gawrilov or "Electroless Plating: Fundamentals & Applications" [on
eBay ,
Amazon, or
AbeBooks (adv.)]
by Mallory and Hajdu
You may also wish to contact suppliers of electroless nickel solutions, such as:
- Atotech
- Coventya
- Heatbath
- Macdermid
A. Electroless nickel is a coating designed to protect metallic parts of any shape against corrosion-erosion in oil industry applications, for example, in choke boxes, control valves, spools, pumps, pipes, and others where corrosion and erosion resistance are required to reduce operational cost and extend lifetime of components mentioned above.
José Wong- Caracas, Venezuela
by G. G. Gawrilov
or eBay or
Q. We are a job shop working closely with electroless nickel plating, however one of our clients wanted to clarification as follows:
"Electroless Nickel Plating (ENP) is not used in wet sour service. ENP shall only be used in dry gas and crude oil service. The ENP, which is hardened for anti galling purposes, is easily damaged mechanically and the damaged areas allow for corrosion of the carbon steel substrate. As the steel corrodes it undermines the thin ENP coating resulting in more of it becoming detached from the ball surface."
Can any specialist clarify whether this is indeed accurate. As per my understanding, ENP is a suitable option (SC4 severe environments) as it offers resistance to Hydrogen sulfides, etc. However manufacturers and applicators may have valid insights to this.
- Dubai, UAE
Ed. note: Can you attribute that quote please, Rajeev?
A. Your client is partly correct. If EN is hardened to more than about 850 HK it will shrink and it will crack, exposing the steel to the environment. Then steel can be attacked (by wet H2S, or acids, or by brine in crude oil) and the EN undermined.
However, if the EN is not hardened, it is very resistant to wet sour streams and is commonly used at temperatures up to about 400 °F.
Ron Duncan [deceased]
- LaVergne, Tennessee
It is our sad duty to note Ron's passing on Dec. 15, 2006. A brief obituary opens Episode 13 of our Podcast.
Q. WELL WE ARE GOING TO USE ENP COATED BALL VALVE IN SOUR SERVICE I ALSO NEED TO CONFIRM IT.
NAVED MAHDI- DAMMAM, Saudi Arabia
July 15, 2009
