Selection of coating resistance value for coal tar enamel on pipe lines
I want to know the coating resistance value for coat tar enamel and fusion bonded epoxy, which are in use on gas pipe lines.
[name deleted by editor at request]
esearcher - Cardiff, UK
Hi Niamat,
I may be wrong but I don't know of any 'value' for coal tar enamel (you said 'coat' but that seems to be a misspelling) and the word 'fusion' for epoxy sounds perhaps wrong ... fusion applies to thermoplastics not thermosets.
For the epoxies, try SHELL for data.
So they are coating gas lines. Interesting. I was told that one the last 2 earthquakes in Japan and in California, where line breakage occurred, it was with concrete, PVC and similarly made piping ... but the Polyethylene pipe DIDN'T BREAK.
freeman newton portrait
Freeman Newton [deceased]
