Letter 39023
Paint removal for old cast iron stove
January 14, 2006
The paint on my cast iron kitchen stove (circa 1900) has chipped and rusted in large areas, too big to touch up. Elbow grease is in large supply here...but I don't know how to get the coating off. Tried using a grinder, not good-dug into the iron. I hope to get this behemoth up and running for home heating an emergency cooking for next winter. I doubt that there is a safe chemical stripper, but any help with getting the coating off so it can be re-painted to at least hold back the rusting would be super. I'm not a hobbyist looking for a total stove restoration. Just looking to provide for the family.
How bout we start a restoration picture exchange to check on each others progress?
Donna Susan Day
Consumer - Rome, PA, USA
January 17, 2006
It looks like what you are dealing with is porcelain and not paint. The best way to remove it it to sandblast it off with an industrial sandblaster. Take proper precautions working around the dust-old porcelain contains lead. After blasting paint with high temp stove paint [Adv. Stove Paint [link is to product info at Amazon] ].
Rod Walters
- Des Moines, IA
January 18, 2006
I would have assumed that it would be a fired porcelain, but that is not indicated, so I will guess a high temp stoving enamel. My guess, since you do not want to use chemicals, would be to find a place that does sand blasting. You will want to blow it off, wipe it down with a tack cloth and apply a suitable primer as soon as possible after the sand blast or it will rust-rapidly.
Paint with one or two coats of high temp spray paint.
Adv. Krylon BBQ, Stove and High Heat Spray Paint (12 oz.)
Dear Reader, please --
My company is a supporting advertiser at finishing.com and we want the contact information to reach the inquirer privately.
List of Directories
Link to Del.icio.us button Save This Page (why?)    -    Home    -    ©1995-2008 finishing.com
