![pub](/gifs/pub.png)
How to prevent danger of adding water to hot blackening solutions
During the hot blackening process water added is dangerous, how do we reduce that problem?
Karunanithi ShanmugamM.O.G,tiruchengode - Salem, Tamilnadu, India
Darned right it's dangerous. People have been killed and others very badly burned. The problem is that these solutions operate at 265 degrees F and up, because of their very high salt content, whereas the water you need to add to make up evaporation losses boils at 212 F. If a pocket of that relatively pure water finds itself under the solution level, and then is suddenly heated beyond 212, it can flash to steam and cause the contents of the tank to erupt and cover everyone and everything with 265 degree+ highly concentrated caustic soda [affil links] .
For this reason I think black oxiding equipment should be purchased from specialty vendors who are well acquainted with the problem and who have accumulated experience with it. But my understanding is that vigorous agitation is needed during heat-up to prevent pockets, but that additions during operation should be made by floating the makeup water on top of the solution.
![Ted Mooney, finishing.com](../portraits/ted_mooney_beach.jpg)
MIL-HDBK-205A, pages 59-60, describes a horizontal diffuser pipe for water additions. A row of drilled holes in the pipe faces the rear inside wall of the tank above the solution level. Also, a needle valve is used to restrict the flow rate. Thus, water enters as a film flowing down the tank wall.
Ken Vlach [deceased]- Goleta, California
![contributor of the year](../portraits/ken_vlach_award_thumb.jpg)
![none](../gifs/none.png)
