How To Rust Craft Store Metals like Jingle Bells & Safety Pins
Intro / synopsis: Actual rusting can be done with materials like salt, vinegar, muriatic acid, or bleach (never mix bleach with an acid!), but it may be complicated by the fact that the original shine might be zinc plating, nickel plating or something else, and these platings may react differently to your rusting solution.
A simple, chemical-free, alternative may be "cinnamon rust look" :-)
Q. Hi all. I'm an at-home crafter and I constantly require "aged" pieces of metal from jingle bells for my projects at Christmas, to safety pins for everyday crafts. I have been purchasing these online at fairly high prices and would like to attempt to "rust" these items on my own. Right now I have a .99 cent package of safety pins and a few gold jingle bells mixed in a rubbermaid container filled with vinegar and salt. *Sigh* they've been there for oh, 3 days now, and NOTHING. The only change I see is on the interior of the bells. The inside is rusting wonderfully but the outside must be treated with something to of course, prevent rust lol. I realize this is an industrial site, but I thought a few of you might be kind enough to share a quick, at-home remedy to breakdown the possible coating on these types of craft items. I have been told in the past that sanding them can help speed things up, but honestly I need something that will do this in a minimal # of steps and be as timesaving as possible. Thanks for your replies!
Susan Jackson
- Mayfield, Kentucky, USA
Q. I, too, am looking for directions to rust bells and pins, etc. quickly. I would appreciate any help. Thank you.
Doris Mary May- Brookdale, Mb, Canada
A. Perhaps try some diluted muriatic acid [on eBay or Amazon (adv.)] (Hydrochloric acid), which should be available at your local hardware store. Make sure you wear rubber gloves [on eBay or Amazon (adv.)], and eye protection ([on eBay or Amazon (adv.)]).
Marc Green
anodizer - Boise, Idaho
A. Safer and simpler is kitchen salt [adv: bulk quantities on eBay or Amazon (adv.)] solution, it must be sprayed or brushed on grease-free objects! Good luck!
A. TRY BLEACH [adv: bleach/sodium hypochlorite in bulk on eBay or Amazon (adv.)] .
Khair Shishani
A. Hi. Okay, I have done this. First thing is to cover it with bleach all day or overnight... maybe even set it in a window or outside, for the heat. Then after you drain it, cover with vinegar [in bulk on eBay or Amazon (adv.)] and salt. Put it outside again all day or over night but check on it later in the day. I hope this helps you.
Paula Hardin- Picayune, Mississippi
A. Try 1/2 cup bleach, 1/2 cup apple cider vinegar and 1 tsp of salt. Put in a jar, cover loosely and let sit for 2 days. Remove with old fork onto paper towels. Set items outside to dry and turn them occasionally, so all sides dry. Piece will rust while drying.
Trish Cooper- Ruther Glen Virginia USA
It can be dangerous to mix bleach and vinegar ... please don't do that!!
Donna Stearns- Hecla, South Dakota
February 8, 2023
A. Take a plastic shoe box type container.
Add safety pins. You can purchase these from a 99 cent or dollar store. You can do a couple hundred at a time. Just so long as it's a single layer of pins. The more pins, the bigger the plastic bin.
Cover with salt. Literally, COVER with SALT [adv: bulk quantities on
Amazon (adv.)].
Also usually available 2 for a dollar at the dollar mart.
Then add peroxide [on
Amazon (adv.)]
. And yep, you guessed it, 2/1.00 at the dollar mart. Usually, 3 bottles should do it. You want about an inch of liquid peroxide above the salt layer.
Store in a non humid area. NOT OUTSIDE, and not anywhere where the solution will evaporate too fast. The process takes about 2 weeks BUT it's well worth it. You actually get rusted pins, not pins that appear to be rusted and then the rust rubs off.
- Victorville, California
Q. Anna . . . Since the pins are ACTUALLY rusted, should the process be done while they're open so that they can be closed? Or, is it no problem to open the pins when the process has been done while they were closed?
Debbie Dellatore- Bloomsburg, Pennsylvania
August 17, 2008
Update: Don't bother trying the above method (salt and peroxide) to get "real" rusty pins. It doesn't work . . . . AT ALL! I tried it and my pins sat in this stuff for 3 weeks. They are still as shiny and silver as the day I bought them.
Debbie Dellatore [returning]- Bloomsburg, Pennsylvania
September 1, 2008
Ed. note: please see the Sharon Gannon's question and the responses to it, Debbie.
A. I went through the same trouble as you! My Mom gave me this "recipe". I use only the cheapo gold pins and bells and this works like a charm.
It does take time but is well worth it.
1/2 cup cider vinegar
1/2 cup bleach
1 teaspoon salt
Mix in a one quart Mason jar. Cover loosely and put in a safe place. I let mine sit for a couple days and then dry them in a paper towel and let them sun dry. They may not look all that rusty but they will rust more as they dry.
- North, Texas
September 29, 2008
Ed. note: Welcome! Feel free to visit anonymously! But our 35-year legacy of warm aloha is incompatible with anonymity; please only post with your full real name.
Q. I'm attempting to rust metal and tin stars, bells, etc., and I'm being unsuccessful. I'm using vinegar and bleach, what else can I do?
Sharon GannonThe Olde Cellar - Wayne West Virginia US
December 10, 2012
A. Hi Sharon. We appended your question to a thread on the subject. First, never mix bleach with vinegar or any other acid :-(
But check that the items are magnetic because, if they are not, then they are not steel and will never rust. Assuming that they are steel, I suspect that they may have a clear lacquer or clearcoat on them which is preventing your chemicals from reaching the metal.
If you have an electrical testing meter/VOM multimeter [on eBay or Amazon (adv.)] , you can check for the resistance between two spots on the objects to see if there is a non-metallic coating on them. Try lightly sanding the area on one item as a test of removing the coating, and check the resistance again, and/or see if the sanded area rusts. You can put them in acetone [on eBay or Amazon (adv.)], which will strip lacquer. If they do have a clearcoat that isn't removed with acetone, it can be removed with Aircraft Stripper, but that's truly noxious toxic stuff.
Then they should rust with any procedure you see on this page. Good luck.
A. I decided to take handmade paper and rust it with the vinegar and salt method. Worked wonderfully overnight (with my already rusted objects on the paper).
Q. NOW, how do I stop any continuing rusting. I am letting the paper dry out ... it is beautiful.
Dona Geib- Reseda, California, USA
May 2, 2013
A. I've tried many different things to get the rusted look also. I've been successful using bleach for 24 hours, then wash them off, dry them, then put them in apple cider vinegar for 24 hours. Remove, rinse, then let them set in the sun to dry and set the rust. This works great for me every time. Hope this helps some of you who're just as discouraged as I was.
Cynthia CampbellStay at home mom - Luray, Virginia United States of America
November 27, 2017
Bleach and vinegar together makes toxic chlorine gas folks. Please don't try this at home.
ellie schaffer- Oak Hill Virginia USA
February 19, 2018
A. Toilet bowl cleaner ... On a cheap cookie sheet, pour toilet bowl cleaner on desired item to rustify and set out in sun
Anna Dery- Saugus, California USA
December 23, 2017
Cinnamon "Rust-look"
A. Hello. Let's skip the chemicals and make it a little easier. Lay your bells and pins on aluminum foil, spray paint black. I use Krylon Colormaster paint & primer in black matte →
Let dry. After they dry you can dip each piece or handful into a bowl of cinnamon [adv: bulk quantities on
Amazon (adv.)], shake excess off by tapping off on side of bowl and let dry. Looks much more like the craft store rusty bells...you will love it! Smells great and is worth it. Have a nice day.
This is a little colander that I bought at my local dollar tree. When I bought the colander the color was silver metal. I used the technique I described but chose not to cover the whole piece but looks just like rust. I came up with this about a year ago and have made some pretty nice pieces with this technique. Thanks.
Deborah AnsarDayton Ohio USA
May 3, 2018
Q. You said you painted with black paint and let dry. Put them in cinnamon and shook off extra and let dry? Cinnamon is dry, so did you leave something out?
Judy Beatty- Greenfield Ohio
November 9, 2020
A. Hi Judy. Deborah's posting was from 2-1/2 years ago, so I don't know if or when she'll reply. But in the meanwhile I'd interpret her instructions as "let partially dry / let dry to tackiness".
I don't know about the longevity of the cinnamon. Back when my son was in grammar school his class had a project to make scrapbook albums with a different grain on each page: rice on one, corn on the next, rye on a third, wheat on a fourth, oats on the fifth. When we brought it down from the attic some years later, it was a scrapbook of which grain different species of grain worms preferred :-)
November 2020
A. The cinnamon rusting technique I use is this: Spray paint item desired color. Let dry. Spray with spray adhesive [adv: adhesive spray on eBay or Amazon (adv.)]. IMMEDIATELY sprinkle with cinnamon. Then spray with a clearcoat of some sort. Repeat adhesive/cinnamon until you achieve look you want. Finish again with clear coat.
J BELTZ- Tamaqua Pennsylvania
October 31, 2021
A. The cinnamon when you put it on an object it looks like glitter; once the item dries, take a paint brush and loosely, very lightly, brush the item. The loose cinnamon will come off ... but you must seal your item to stop it flaking or coming off more! You can use a clear coat spray or mod podge to seal them.
Penny Martin- Erin New York
January 6, 2023
Q. I'm wondering what makes the cinnamon stick to dry safety pin? Don't you need glue or mod podge on first?
Dwanna Thoroughman- Garden City, Michigan
April 22, 2023
A. Hi Dwanna. Yes, you certainly need something -- I think some of the wording has been unclear, but J Beltz suggests spray adhesive, and mod podge is probably okay too..
Q. I want to rust safety pins, but will the rust-resistant nickel plated "modern" ones rust?
Kate mojo- Davis California
January 26, 2021
A. Hi Ms. Mojo. The nickel plating itself can't rust, and it deters the underlying steel from rusting, but it does not prevent it if there is porosity or pinholes in the plating, which there usually are. The rust will appear in the form of pimples through that porosity, but you won't get an even rust finish. Here's a pic of a nickel plated bicycle fender where you can see the pimply nature of the developing rust, and a nickel plated bathroom rack for sale at a big box store already rusting if you look closely.
Several folks on this page suggest using cinnamon to imitate rust; I personally haven't seen it, but it sounds like a good way to go when dealing with nickel plating which isn't rusting :-)
