Woods Nickel variations
Q. Hello, I was looking for a nice and simple alternative to cyanide copper strike for decorative red brass plate over steel. This is to refinish all the original door hardware in my 1925 Craftsman-style home. It looks like woods nickel might be the best bet. (Unless there is something simpler and cheaper?) But reading up on woods nickel strike, it seems like there are as many formulations for it as there are users. Here's some I've seen:
240g/L NiCL2.6H2O + 360ml/L HCl
250g/L NiCL2.6H2O + 250g/L HCl
240g/L NiCL2.6H2O + 120ml/L HCl
70g/L NiCL2.6H2O + 13g/L HCl
I assume the higher concentrations should plate faster and better on smaller parts while the more diluted variations would be easier on delicate parts. But are there other reasons for these variations?
And if Woods nickel is the way to go, could anyone give more details, i.e., anode composition, bandage?, ASF, CFM, incompatible base metals, temp range, etc. :)
Thanks in advance for any help,
Craftsman - Toledo, Ohio
A. Different companies have reasons why they prefer one formula over others. Speed of deposition is actually controlled more by the HCl concentration than the nickel. The higher the percentage of HCl, the slower it plates. They all plate painfully slow, but you only plate to a showing of color. Since you mention bandage, you are talking about brush plating. I do not think that they use Woods nickel for a nickel strike. In the long run, it is cheaper to use the chemicals from a significant vendor than to reinvent the wheel yourself. The will probably give you a copy of their plating procedures if you ask nice. They would like to sell you things like anodes and covers also.
James Watts- Navarre, Florida
Second of two simultaneous responses -- 2005
A. A Wood's nickel strike is commonly used for stainless steel and other alloys which self-passivate upon rinsing after acid activation. It would certainly be helpful for steels having a tendency to flash rust, and a Ni layer will add to the corrosion resistance of your hardware.
Your 3rd Wood's nickel formula is commonly used, with the (8 to) 12 vol% HCl based upon the use of 36 wt% HCl (specific gravity 1.18). With a less concentrated HCl source, adjust the volume accordingly. E.g, 10-14 vol.% for HCl (30 wt%). Use at ambient (indoor) temperature.
Note: These concentrations are suitable for stainless steel; a lower HCl level might work for steel. Avoid assumptions, keep records and learn from your results.
Read the excellent Wikipedia on Hydrochloric acid .
and note concentrations and the high vapor pressure. Hence, it is highly advisable to cover the tank with a plastic lid when not in use -- first remove the cathode bar (copper) & the anodes (with rinsing). It is also advisable (and perhaps legally required) to use secondary containment, so your tank should be within a larger tank or cut-off plastic drum.
Titanium baskets containing nickel pellets ($$$) are used as anodes in mass production. For your application, an inert graphite anode is more appropriate. Graphite pieces can be bought on eBay. Graphite is quite brittle, so use care in drilling through-holes for clamping (to a copper anode bar) or blind holes for threading. Or simply, purchase graphite electrodes (with or w/o threaded holes) from a 'Chemicals & Perishables' supplier at the link below.
For plating, 30 Amps/ sq. ft for 6 minutes is ample. A brief initial period with the power off, or with the current reversed (workpiece anodic) for stainless, is normally used for cleaning/surface activation. Do only as necessary for good adhesion; it causes undesirable iron build-up in the bath.
Platers like annealed copper wire (soft, conductive) for hanging parts. Copper dissolves in acids, so you may wish to pre-plate some lengths of wire: Lift the cathode bar, attach the wires, turn the power on and put the cathode back upon the tank (go in 'hot'). Re-use the wires as practical.
- Goleta, California
Finishing.com honored Ken for his countless carefully researched responses. He passed away May 14, 2015.
Thanks everyone for your responses.
Q. I was wondering if some red brass (85% Cu/15% Zn) could be dissolved in HCl + H2O2 to produce CuCl2 and ZnCl2? Then if HCl and water is added to bring the pH to say 4.0, could that be used as a "woods brass" strike over steel? Then could I fill with acid copper and top with this "woods brass" again as a decorative finish? Thanks!
A. Sorry, Mark, but alloy plating like that won't work. If you look at the electrochemical series you will see that copper is far far more noble than zinc (well over a volt difference, and enough to power children's "lemon batteries" and "potato clocks"). Your deposit will contain no zinc even if you have 100x as much zinc in your anodes as copper. Alloys can only be deposited when you have a complexor/chelator that very effectively ties up the noble metal (cyanide is most often used for brass plating).
Hopefully you know that cyanide is very dangerous, creates a gas chamber if acidified, and is utterly inappropriate for home use.
A. Mark - send it to an electroplater.
Daryl Spindler, CEF
decorative nickel-chrome plating - Greenbrier, Tennessee
Thanks everyone. I agree that cyanide is not a do-it yourselfer kind of project, at any discipline. If possible I'll try to get some kind of strike plate on the items + acid copper + cut/color and see what the local plater will charge to finish them. I didn't want to go this route as there is only one service in town and they have been rather pricey in the past. I also don't know if they do brass and specifically, red brass... But thanks for the help.
Mark Jones- Toledo, Ohio
