Plating to meet 1000 hrs SS and be hex free
I have had a customer request for a plating/coating to meet 1000 hr salt spray (ASTM B117) and also be RoHS compliant. Is there such a plating/coating?
Perry Longhurst
- Peterborough, Ont., Canada
Hi,
You can use stainless steel. Which is the best for your application. Passivation can withstand max of 500. Super black zinc passivation can withstand max of 500 hours to get Red Rust and max of 150Hr to Red Rust. Next best is Non Hex Chrome Blue passivation which will withstand 350 hours for Red Rust and 125 hours for white Rust.
Best Regards,
Faiz Jalal
- Hyderabad, India
I have heard that a minimum of 0.0015" per side of electroless nickel will get to 1000 hours. I have also heard that a good powdercoat over zinc phosphate will get 1000. Check with your plater or painter.
Both you and your client need to determine what type of corrosion you are looking for 1000 hours to. Is it red corrosion (rust) or white salt? On which significant surfaces? What is the substrate? What properties must the finish possess or not have?
Information is vital to getting accurate helpful answers and also to performing processing correctly in the clients estimation.
Gene Packman
First of two simultaneous responses -- 2005
Hello Perry,
It is entirely possible to exceed this 1000 hour standard. There are a number of coatings
Zinc Nickel alloy followed by Trivalent Greenish Thick passivate.
Electrophoretic lacquer of the Epoxy Pu type.
Zinc Cobalt allot with a sealant of the inorganic type after the light green thick chromate.
You need determine the end point of the 1000 hours is white or red rust and what is the base metal and where the component will be fitted before selecting from the myriad choices that are readily available of which the above is a sampler.
asif_nurie
Asif Nurie [deceased]
- New Delhi, India
Electropolishing should get you to 1000 hours in a salt cabinet or more. I recall one test that was terminated at about 1200 hours... no rust yet on the electropolished stainless.
Todd Turner
- Monroe, Louisiana
Dear Perry,
I will add to what Asif Nurie said.
Alkaline Zinc-iron with followed by trivalent black passivation and a sealant will give you 1200+ SST Red Rust.
If you are more specific about your requirement and SST, I may be able to give more details.
t k mohan
T.K. Mohan
You should try E-coat. This will give you a minimum of 1000hrs salt spray. Most e-coat processes have a zinc phosphate pre-treatment. This is necessary to give the paint the proper adhesion. The mean thickness is usually .8-1.2 mils. This means that you can paint threads and small enclosures.
Adam Adkisson
- Seminole, Oklahoma
Hi Perry,
I'd like to clarify and add a few points:
1. E- coat may pass 1000 hours SST only on tubular/ wire/edgeless parts only.
2. Sheet Metal parts with edges will see shrinkage and will not get you past 1000 hours without Red Rust.
3. Zinc Iron that passes 1200 hours will contain Hex-Chrome. It will not be RoHS compliant. It is not an option.
4. Zinc Iron with Trivalent Chrome will not last 1000 hours.
5. You may require a duplex coat of zinc-nickel or zinc-iron plating with Trivalent chromate followed by a topcoat of E-Coat.
None of the above alone will work.
Khozem Vahaanwala
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
saify logo
Q. Dear Mr. T.K Mohan,
I require 1000 hrs of Red rust in Zn-Fe Trivalent. Please guide related to my requirement.
Kuldeep
- Gurgaon-Haryana, India
December 26, 2012
