Letter 38088
Gold peeling test on semiconductor
devices [U.K.]
We are currently looking into how to test for gold peeling on the
backside of small components average size from 1 mm to 5 mm surface
area
We currently Epoxy place the components with no visible filet up the
sides of the devices followed up with dice shear process
This does not give the best results because if the epoxy climbs the
sidewalls of the components, you then have a false reading because
you are testing epoxy strength not the gold adhesion (It is very hard
to dispense small amounts of epoxy so that we achieve the correct
bond line thickness or spread
We also have eutectic attached some devices but due to the heat
applied this again
Can cause excessive heat on the plating process
Some suggestions we have had is place the device gold side up over
and ball bond on to the surface .Followed up with ball shear
test
Does any one have this particular problem and what do you suggests we
do to tests our plating on small devices
Rob Naisbitt
Filtronic - AYACLIFFE, U.K.
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
