Letter 38087 Titanium heaters in chromic acid+++++ We use titanium sheathed heaters in 122-15% chromic acid
containing free iron radicals. Temperature maintained is 70 Deg
C. MANOJ M DESAI
+++++ According to the chemical resistance charts and prior experience the only electric heater shells that stand up to chromic acid/sulfate plating solutions are those with an outer shell of Quartz or Teflon (PTFE). Gene Packman
+++++ Hi Manoj
+++++ As we all know, chromic acid is disgusting stuff that creeps everywhere and attacks just about everything. Gene and Freeman are right in suggesting a polymeric or ceramic coating to protect the heaters - pH will not be an issue because chromic acid has such a low pH that is almost falls off the scale!
+++++ Use lead bonded heater for chrome solution. Salim
First of two simultaneous responses -- +++++ From the life of your Ti heaters, I will guess that you are using full rated heat in your heaters. For longer life, use derated heaters and for even longer life, use double derated heaters. James Watts
Second of two simultaneous responses -- +++++ Trev. Freeman Newton
Dear Reader, please --
Save
