Letter 38035 Galvanic corrosion of alloy steel fasteners in stainless+++++ We are experiencing alloy steel bolts (grade 10.9) corroding and breaking in large stainless steel assemblies being used in the food industry. The environment is hot (200 F) and humid with caustic solution occasionally being used to wash the equipment down. The bolts are Geomet Plus coated as this is FDA approved (no hexavalent chrome). The bolt heads are breaking off due, I think, to stress corrosion compounding the galvanic corrosion. Where the moisture is staying in contact with the bolt, the corrosion is worst. I was thinking about assembling the bolts using RTV under their heads to prevent moisture ingress. Zinc Chromate primer is an FDA no no! Would greatly appreciate your thoughts please. Thanks. Martin Hughes
+++++ A grade 10.9 bolt is extremely hard. I am unsure what the exact
material and finish is that you are using on these bolts. If it is a
carbon steel bolt with electro-deposited finish you are experiencing
a delayed brittle failure due to hydrogen embrittlement. I would
investigate the plating specification and proceed from that point.
Reference ASTM B-633 [link is to spec at TechStreet] as
a guide for preventing this failure. It is unlikely that the bolts
are failing due to corrosion. The location you are describing is
where delayed brittle failures usually occur. Jason Siewert
+++++ The bolt material is required for the tensile properties to provide an adequate safety margin. A2 or A4 stainless bolts are not strong enough. We have been assured that the Geomet coating does not induce hydrogen embrittlement. However, it doesn't appear to help prevent the galvanic corrosion as the zinc is far apart on the galvanic table. Corrosion is prevalent all over the bolt, but mainly in the area where it is kept wet. We were wondering if Armoloy or Xylan coatings would be more appropriate for the mating stainless parts to reduce galvanic corrosion. Armoloy, being thin dense chrome, is closer to stainless on the galvanic table and Xylan is non-metallic. Martin Hughes
+++++ Jason is probably correct, but there is also a possibility of
thread seizure.
+++++ Bulten Stainless of Sweden makes a corrosion-resistant fastener in
a high strength, high Mo version of 316L. Available from
Unbrako.
Ken Vlach
+++++ Many thanks for the link to the Bulten stainless screws. That will be very useful as it will probably solve my problem if they have stock! Martin Hughes
While the Geomet coating may not induce hydrogen embrittlement, remember that coating processes involve pretreatment, and if cathodic cleaning or acid activation were involved (as opposed to strictly mechanical blasting for pretreatment) these introduce the possibility of hydrogen embrittlement.
February 17, 2006 Several years ago I learned of some failures to stainless steel
screws due to unexpected causes. These were building facade
failures. Drake Jacobs
Dear Reader, please --
Save
