Letter 38032
Hardness on chrome plating surface on IC engine valve
We are chrome plating the stem portion of the valve to a thickness of 5 - 10 microns.
we need to achieve a hardness of the hard chrome surface to 900 Hv 0.10 kg minimum.
what are all the process input requied.
We are using high speed salt with additive.
Ramasubramanian Arumugam
- Bangalore , Karnataka, India
First of two simultaneous responses -- +++++
Since we have no idea of the salt or the additive, the only people that can answer your question is the vendor's tech service dept.
- FL
Second of two simultaneous responses -- +++++
Mr Ramasubramanium
The Tech data sheet from your supplier is your best friend. Read study memorise the operating conditions and implement these.
Conditions and factors affecting hardness are generally
temperature
Current Density
Sulfate ratio to Chromic acid.
Catalysed baths have specific conditions that need accurate implementation.
Asif Nurie
Atlanta Global Limited
New Delhi, India
Dear Reader, please --
My company is a supporting advertiser at finishing.com and we want the contact information to reach the inquirer privately.
