Letter 38027
Name for dipping red hot steel in oil
What name is given to the process, where u heat the steel to a
cherry red and then dip the heated object in engine oil. I have used
this many times in the workshop, at university as it gives a black
finish that does not corrode. I was just wondering if any one could
tell me the technical name for this process as I am doing a project
and need to name the above process.
Many Thanks
Robert, Wilson
Student - Portsmouth, Hampshire, England
First of two simultaneous responses -- +++++
Robert,
The name I'd use is VERGLUEHEN (VERGLÜHEN) ... Normally the 'U'
is or has an umlaut, the twin dots over it instead of 'ue'.
It is an annealing process, is it not.
By the way, back in l922-ish, my grandfather, a naval architect, was
responsible for upgrading the Victory and seeing that you are a
Pompey-ite, I thought you'd be interested.
Freeman Newton
- White Rock, B.C. Canada
Second of two simultaneous responses -- +++++
Quench is one name.
- FL
For steel, it is a hardening process. Annealing is holding the
part at an appropriate temperature, like 400F, for a given period and
letting the temperature coast down,
- FL
How about "oil quench".
R&D practical scientist - UK
March 13, 2006
It is called oil blackening and is often used when treating gun
barrels to give the blueish look due to the type of oil used.
Jabulani Johnson
- Bristol
April 21, 2007
I think the process is called tempering.Tempering has two stages ,
Fistly the material is heated above a critical temperature then
cooled rapidly (quenched) to freeze the material in a hardend
state,Then the material is heated to a lower temperature to refine
the grain structure to give hardness suitable for the job intended
jim conkey
- Perth Western Australia
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
