Brass coating removal from shower fixture
I have Shower fixtures which are nickel with a brass finish. A shower cleaner ate through the brass in spots and left black streaks. I need to know what I can purchase to remove what brass is left.
Edverda Francis
student - Eynon, Pennsylvania, USA
It sounds like this wasn't brass, but a tinted lacquer or translucent plastic coating; lacquer thinner [on eBay or Amazon (adv.)] may remove it. If not, it sounds like you've already found a shower cleaner that will. Try applying the thinner or the shower cleaner with 0000 (very fine) #0000 steel wool [on eBay or Amazon (adv.)].
