Letter 38005
Can electroless plating deposit Inconel
625?
We are having a industrial hard shop and recently had an enquiry
whether it is possible to have an electroless plating using Inconel
625 (Nickel alloy). I understand that this alloy has high corrosion
resistance. Wanted to know whether such a process exists for this
compound and who can help in this process.
GEORGE ABRAHAM
- KUWAIT
If your EN is from an international company, they have somewhat of
an obligation to help you with a proper process or risk losing you to
another company.
If it is a "home brew" you are going to have to get into the books.
You may find some help at the INCO web site.
Being high nickel, it is tough to activate in comparison to other
materials. A very clean part is important. Avoid anodic caustic
cleaners with very high caustic levels. Periodic reverse is ok, and
would be my choice as soak cleaning is slow. Experiment with various
acid activators. Rapidly rinse and get into the EN tank as it will
passivate rapidly. If is amenable to rapid movement, a warm rinse
tank is better than a cold one as EN plating will start faster, (but
the water film will dry much faster). You might add enough ammonia to
raise the pH to 8 which will allow a faster start of plating in the
EN. frequent small additions will be required, depending on the
amount of acid drag in. If your adhesion requirements are high, you
might have to use a Woods nickel strike before the EN.
- FL
There are no electroless processes for
depositing alloys like Inconel.
Ron Duncan
Palm
International, Inc. -
LaVergne, TN
Ed. note:
It is our sad duty to alert the readers to the passing
of Ron Duncan on Dec. 15, 2006. For those who would like to
know more about him, a brief obituary opened
Update No. 13 of our
Metal Finishing Industry Update Podcast.
I did not read the question correctly. Ron is absolutely correct.
- FL
Dear Reader, please --
- Answer or follow-up on this
subject (in non-commercial
fashion).
- Post a new
question or inquiry on a
different subject.
- This is a monitored
forum. If you spot broken links or obsolete info, please
advise!
