Info about unusual surface roughness symbols
Q. Respected Sir,
I require some detail information about the surface finish symbol shown below:
3709
It is 2.9 MM thk. and 60 MM wide. There are slots of 2.95 MM width at an angle of 30 degrees each at a pitch of 26 MM. The dimensions are according the DIN standards. The term "1.5/Pt 25" has to be understood.
I was really happy to get some interest for my topic. Looking forward for your co-operation.
Thanking You,
Yours Sincerely,
UMANG CHAVADIA
A. The American National Standard ASME Y14.36 establishes the profile for surface textures. The roughness sampling length is placed below the horizontal extension.
Bruce Solana
- Panama City, Florida
Q. I have a drawing of a cast steel component. One of the drawing notes contains a finishing mark I have never seen before. This mark starts with the Roman numeral III followed by the check-shaped finishing mark. The entire note reads: III(check-mark)Surface Quality per 2A 296-1004. What does this mean?
John Bauchat
- Milford, New Hampshire, USA
Q. We have a customer drawing that specifies 1.0 Finish mark, and under the mark it reads 0.4 / Rt 6.3 with a "C" under the 0.4
What do all these numbers and letters mean?
John Smoyer
job shop employee - Jackson, Michigan
Q. We have a customer drawing that specifies:
"0.9/Pt6" above the Finish mark
Appreciate your response.
Zhu Jinghong
