I put muriatic acid on a object; it turned pinkish brown
I put muriatic acid [affil links] on a object thought to be gold it turned pinkish brown what does that mean. I'm a small beginner collector of nic nacs.
Brad Kelling
self interest - Walnut Creek , California, USA
It means it's not solid 24k gold, but it doesn't mean much more than that. Spot testing of metals must be done in accordance with a predeterminded tree structure. To conduct one test from the middle of the tree and ask what you have is unfortunately rather like taking one step from a recipe, "add three eggs", and guessing what it's a recipe for.
I believe that a simple spot test tree can be found in the Metal Finishing Guidebook, but there are whole books on the subject (Rapid Spot Testing of Metals & Alloys [on "on Amazon (adv.)] by A. Holmes, Spot Tests in Inorganic Analysis by Fritz Feigl).
Hydrochloric acid is nasty stuff and I hope you are using some guidelines for safe experimentation.
