Nickel plating / striking on stainless steel
< Prev. page (You're on the last page)
Q. I'm having trouble electroplating 304 stainless. It has been polished, then cleaned through a electro cleaner first on reverse polarity and then positive. Then rinsed, 10% sulfuric, rinsed, then Wood's nickel strike. Then directly into bright nickel, and chrome. Blisters 60% of the time. Peeling seems to be nickel strike off the stainless. Any ideas? Maybe a better activation process to activate the stainless?
Brett Troncale- Santa Fe springs, California
March 18, 2014
A. In my case I don't like to electroclean reverse; it does passivate stainless steel, just cathodic electrocleaning.
Daniel Hernandez Guerra- Bucaramanga Santander Colombia
April 1, 2014
A. Hello Daniel,
Most shops use HCl pickling on steel before Ni strike, not a sulfuric dip. I also agree that a cathodic clean is the way to go.
Process Engineer - Malone, New York USA
April 2, 2014
A. Maybe you have left the anodes in, and the nickel concentration increases, and you convert an inefficient STRIKE solution into an efficient PLATING solution which will not bond. Take your anodes out when not in use, titrate and adjust the metal down to 16 oz/gal nickel chloride and 32 fluid ounces per gallon HCl.
A. I would like find out blister base -- substrate to Ni strike, or bright nickel to other nickel, or chrome layer. I think you have a cleaning problem; soak clean, follow up by anodic electroclean and anodic acid (10%) sulfuric acid (CLEAN).
Popatbhai B. Patel
June 23, 2014
Q. Electrolyte which can be used in the electroplating of stainless steel and only nickel?
Why electroplating of stainless steel and nickel is not possible?
- lucknow,u.p., India
September 7, 2014
Hi Monica. I'd like to try to help you but your questions are too brief for me to understand.
September 7, 2014
A. Monica,
Plating on SS material is a tough task.
It is an inert metal.
Try with Wood's nickel strike prior to nickel plating.
- Bangalore, Karnataka, India
September 13, 2014
Q. I have a print for a metal stamping that I need to purchase. The material calls for .25 MM stainless steel with nickel plating OR 0.10" CRS with bright tin plating. My question is, will these two types of materials/finishes, give the same performance? And, why would you need to plate stainless steel? Is that accurate? Thanks.
Lee Smithbuyer - Rolling Meadows, Illinois, USA
December 11, 2014
A. Hi Lee. We appended your inquiry to a similar thread where the question of why you might plate stainless steel is already somewhat answered -- for example, it's a better electrical contact surface, and it's more solderable. Unfortunately, 3rd parties can only guess why the designer wants the stainless steel nickel plated, and our guesses may be wrong.
There is no way we can say whether nickel plated stainless or tin plated CRS is better for an unknown application, but the tin plated CRS is probably a good deal less expensive. Best of luck.
February 2015
Q. I have been trying to electroplate my stainless steel Apple Watch, I did it using these steps and it didn't work; can anyone pick out where I have made a fault?
Step 1. Clean watch with alkaline solution, and run submerge test x2
Step 2. Clean with acid pickle and submerge
Step 3. Plate with nickel and submerge
Step 4. Plate with gold
When plated with gold it didn't show up. What could we have done wrong?
- Lowestoft, Norfolk, England
September 12, 2015
A. Hi Rejaul. Have you enjoyed success gold plating other items? What other items? Were they made of stainless steel? Does your watch now have a nice shiny adherent plating of nickel on it?
September 2015
Q. Hey ted,
No this is the first item I am gold plating. How can I tell if there is a layer of nickel on the watch? It looks exactly the same to me. I assume there must be a step I'm missing
September 16, 2015
A. Hi again Rejaul. You're welcome to attempt anything you want to attempt. But if you have never done any plating and your first attempt is going to be on an expensive stainless steel item of unknown composition, you have a difficult task in front of you both because of potential damage and because stainless steel is difficult to plate.
Still if you are running electricity to the part, you are moving electrons from the anode to the cathode and something has to happen at the anode and cathode as a result because Faraday's Law of Electrolysis won't be violated. Tell us about the bubbles you're seeing in the nickel plating tank and in the gold plating tank.
September 2015
October 23, 2015
A. You need a high chloride bath Nickel Wood's Nickel
Range Optimal Contents: Nickel 80- 96 gr/lt, 88 gr/lt Nickel Chloride 420-467 gr/lt, 434 gr/lt Chlorhidric Acid 70- 82 gr/lt, 75 gr/lt 3 to 5 volts
I hope this can help you. Regards.
Q. Hello Ted, can you please elaborately explain to me How The Above Composition Has Come And How It is Useful
Best Regards
- Hyderabad, India
Hi phani. The Wood's Nickel Strike was invented and developed by Donald Wood, a founding partner of Hill-Cross Company [a finishing.com supporting advertiser] in West New York, NJ.
As a young man I had the pleasure of knowing Don. He loved pumpkin pie, and I lived near a famous baker of them; in return for bringing him a pumpkin pie a couple of times, he was kind enough to show me some of his achievements :-)
The primary purpose of the process is to allow plating on stainless steel.
Q. I read one of your previous posts recommending Woods Nickel strike as best for stainless steel. You mentioned that the nickel concentration should be monitored with 90 g/l as the upper limit. What happens above 90 g/l?
Suzanne M Ingalls- Anoka Minnesota
December 7, 2015
A. Hi Suzanne. We have some 50,000 threads here and I can't easily find the one where someone claimed that 90 g/l is the upper limit. But the most obvious thing is that if the nickel concentration is too high, the process may function as a plating bath without attacking and activating the stainless, and you'll have low adhesion.
But please tell us your own situation -- it's tough to predict all the things that might go wrong in 101 scenarios if the process gets out of control and the nickel is too high :-)
December 2015
Purpose for nickel plating stainless steel in electrical applications
Q. I'm investigating an issue we are having with an 18-8 stainless steel screw (pan head, drilled spanner drive), which is being used as the contact for the positive terminal of a Lithium battery. Under shock and vibe, we've measured a voltage drop at the interface between the screw head and the battery terminal. We believe that the battery terminal is nickel plated stainless steel, however the screw is not plated. During our testing, we've found that if we nickel plate the SS screw, then the shock induced voltage drops no longer appear.
I would like to better understand why the screw needs to be nickel plated, in general, why is it necessary to Ni plate SS for electrical applications (assuming it IS necessary)? SS appears to be conductive enough, as we do not measure a voltage drop along the length of the screw, only at the interface to the battery. Assuming the Ni-SS "interface" within the battery terminal does not induce a voltage drop, why does the Ni-SS interface between the battery and the screw create a problem, such that I need a nickel-nickel interface there?
Electrical Engineer - Carlsbad, California, USA
March 21, 2016
A. Hi John. When a non-precious metal is exposed to the atmosphere, the surface of the metal reacts with the oxygen and sulfides in the air and forms reaction products on the surface. These reaction products are not metals and tend to not be conductive. The resistance offered by this skin of reaction products can interfere with the passage of electrical current. The tarnish that forms on the surface of nickel is not as thick, resistive, and problematical as that which forms on stainless steel ... but whether that is because of the chrome or the iron in the stainless steel, I don't know.
March 2016
Q. Thank you for the quick reply, Ted.
It's my understanding that for stainless steel, this reaction is also known as a passivation layer, and is made of Chromium Oxide (Cr2O3), and is extremely thin. Stainless steel, even with the passivation layer, isn't all that resistive, though Cr2O3 has about 50x the resistance of SS, which itself has about 10x the resistance of Nickel, which is about 4x the resistance of Copper. Because the Cr2O3 layer is very thin, it doesn't contribute very much to the overall resistance of the SS structure (in this case, a screw). From what you're saying, it sounds like the purpose for Ni plating SS for electrical applications is to reduce the surface resistance from the passivation layer. Our experiments have shown that in a static (non-vibe or shock) scenario, the electrical connection through the non-plated screw is just fine. So it seems that maybe there's something more to it. Perhaps it has something to do with the hardness of the Cr2O3 layer (connector pins are often plated with soft metals like gold to improve reliability)?
Anyway, when we nickel plate the screw, I assume the passivation layer still exists (between the SS and the Ni), and that the plating doesn't strip it away... or does it?
Thanks again.
March 21, 2016
A. Hi. The Wood's Nickel Strike simultaneously removes the oxide layer on the stainless steel while depositing nickel in its place. The purpose is to remove the oxide layer so good adhesion can be achieved.
June 4, 2016
Q. SIR ! :) .
I TRIED TO VACUUM BRAZE Bv Ag 6-B (FILLER METAL) ONTO BASE METAL (SS 304 L) IN A VACUUM FURNACE. WHEN, AFTER THE PROCESS, WE TOOK OUT THE ASSEMBLY FROM FURNACE THE FILLER METAL (Bv Ag 6-B) BALLS-UP ALONGSIDE OF THE NOTCH TO BE BRAZED.
WE ARE THINKING OF CLEANING THE SURFACE PROPERLY (SURFACE PREPARATION) AND NICKEL PLATING THE SS 304 L BASE METAL.
I HAVE THE FOLLOWING QUESTIONS .
1) SHOULD I DO NICKEL PLATING FIRST OR SURFACE CLEANING FIRST ? .
2) WHAT MATERIAL AND PROCEDURE (FOR BOTH CHEMICAL AND MECHANICAL) SHOULD I USE FOR SURFACE CLEANING ? .
3) AFTER HOW MANY DAYS AFTER SURFACE CLEANING WILL THE BASE METAL (SS 304 L) REMAIN VALID FOR NICKEL PLATING ? .
4) WHAT IS THE EXACT LINEAR PROCEDURE FOR NICKEL PLATING ON SS 304 L - I MEAN THAT WHETHER WE SHOULD DO (WOODS NICKEL STRIKE FIRST AND THEN THE SUBSEQUENT NICKEL PLATING PROCEDURE) OR WHAT SHOULD WE DO IN YOUR OPINION ! .
5) HOW MUCH TIME AFTER NICKEL PLATING IS THE ASSEMBLY (SS 304 L + FILLER METAL) VALID FOR BRAZING - MEANS FOR HOW MUCH TIME AFTER PLATING CAN I DO BRAZING?
6) WHAT EXACTLY IS WOOD'S NICKEL STRIKE - IS IT AN INITIATION PROCESS FOR NICKEL PLATING?
7) WHAT IS Ni flash ? .
PLEASE ANSWER THESE QUESTIONS IN NUMBER SERIAL-WISE.
I WILL BE VERY MUCH OBLIGED AND THANKFUL TO YOU :)
THANKS IN ADVANCE .
WAITING FOR REPLY :) .
- KARACHI, SINDH, PAKISTAN.
A. Hi.
1. You must do surface cleaning before you can do nickel plating.
2. There is nothing wrong with sandblasting or bead blasting as the first step in preparation, but it may not be necessary. But after that you must alkaline electroclean, rinse, dip in dilute hydrochloric acid, rinse, and do a Wood's Nickel Strike.
3. The purpose of the sequence is to get the nickel plating completed while the surface is still clean and active. That means any delays are bad because the surface can get dirty again or passive again. After you have achieved a successful pattern of pretreatment, plating, and brazing you might experiment with allowing some amount of time between steps but -- until you do -- allowing any time at all is an impediment and a complicating factor in a process that you haven't yet tamed.
4. The first pattern I would try would be blast, alkaline clean, rinse, HCl activate, rinse, Wood's Nickel Strike, rinse, Nickel Plating.
5. I have no brazing expertise and cannot answer.
6. Wood's Nickel Strike is a very acidic, dilute, nickel plating solution intended for activating stainless steel. The theory is that it is very difficult to keep stainless steel from instantly tarnishing with a tarnish layer which makes proper adhesion of plating impossible, but a Wood's Nickel Strike can dissolve that thin tarnish layer, while simultaneously depositing in its place a thin layer of nickel. The thickness of Wood's Nickel is too low to be useful for most purposes except as a base layer for subsequent nickel plating.
7. "Nickel flash" is a general term, rather than a specific term, and it just refers to a thin layer of nickel plating, generally too thin to serve as a final finish on its own. A Wood's Nickel Strike would be an example of a nickel flash.
Q. SIR, I HAVE NICKEL PLATED MY STAINLESS STEEL 304L FOR VACUUM BRAZING -- IT WAS SUCCESSFUL :)
THANK YOU SIR.
SIR I HAVE SOME PROBLEMS:
1) IS IT NECESSARY TO CLEAN THE NICKEL PLATED SS 304L SURFACE BEFORE BRAZING? (PLEASE ELABORATE THIS POINT)?
2) IF YES ! THEN HOW AND WITH WHAT MATERIAL?
STUDENT . - KARACHI , SINDH , PAKISTAN .
June 27, 2016
5. I have no brazing expertise and cannot answer :-)
June 2016
Nickel-chrome plating of stainless steel
Q. Is it possible to electroplate Nickel chrome plating on base material of ss 304 and what is the life of this type of plating and what is the testing procedure by manually.
Thanks and regards,
- Faridabad Haryana India
October 15, 2016
A. Hi Devendra. Yes, once you have properly applied the Wood's Nickel strike or other nickel strike to the 304 stainless steel as discussed in this thread, you can proceed with nickel plating and then chrome plating. The life should be more than acceptable, but it doesn't have an expiration date like bread or pharmaceuticals. There are large texts about testing, but you probably need to test for adhesion and for corrosion resistance as a minimum. Please name some of the electroplating texts in your library and we can refer you to specific chapters; if you don't yet have any plating texts, please go to our "Must-have books" section and consider a couple. Good luck.
October 2016
Plating on stainless jewelry cracks when engraved
February 25, 2017Q. Hi All
I have encountered a problem and would like some clarity on the issue.
A plating company has been plating nickel on my mild steel small rings (50 mm diameter x 3 mm thick) for me for the last year and I have been engraving on the finished face with no issues; but I have just started using stainless steel ...
They are flashing first and then nickel plating, but when I have tried to engrave them, the plating is cracking! We think that this is because the stainless is much harder than mild steel and the nickel is not taking to the metal as easy as the mild steel, or could it be the flashing has something to do with it?
Any advice would be much appreciated.
Only option I see is to go back to mild steel and waste the 1000 stainless rings I have made :-(
Regards joseph
Joseph Kameron- London England
A. Hi Joseph,
Have you heard of a thing called the REACH regulations? In there, restrictions apply to the use of certain substances in certain ways of use (Annex XVII Restrictions). Nickel is restricted for use on items in intimate contact with the skin unless it can be shown the release of nickel is less than a certain value (0.5 micrograms per square centimeter per week). If you cannot verify that the release of nickel is below that figure you are breaking the law in the European Union.
To be honest, if you have stainless steel you shouldn't bother with nickel plating it at all. If it was me I would engrave directly into the stainless steel and then if I felt it necessary passivate with a citric acid type passivation solution.
February 27, 2017
A. While Mr Terry's advice was extremely important if you are making jewelry "rings" to be worn on people's fingers, I read the context differently, in that I have no way to know how you will use the "rings" but that you have an adhesion problem of nickel to stainless steel. If that is the case, then your plater has to tighten up his control of his nickel chloride strike. One pound per gallon nickel chloride and 1 quart per gallon HCl, rolled depolarized nickel anodes (NOT S-rounds), bagged, removed when not in use. And he has to rack them individually, barrel plating probably will not activate the stainless steel.
A. Joseph,
I'll split the difference between the two preceding comments.
Stainless steel is very difficult to plate on, so probably your plater is not doing the preparation correctly which is causing the issue.
The REASON stainless is difficult to plate on is because it's quite resistant to reaction with other things, which is the entire point of stainless steel in the first place. Which is to say, there is no reason to pay the extra money for stainless steel if you're just going to cover it over. Mild steel is cheaper to buy and cheaper to plate. Use stainless if you want the metal itself, rather than a coating, to be the exposed surface.
Ray Kremer
Stellar Solutions, Inc.
McHenry, Illinois
February 28, 2017
A. I assume the reason for nickel plating the stainless steel is to give it a nickel look. I would suggest you engrave the stainless steel, then have someone apply a nickel PVD finish. The finish is not really nickel, but a hard carbo-nitride of titanium, zirconium (most likely) or chromium. We do this regularly on stainless steel watch parts.
PVD Consultant & Wine Lover - San Diego,
California
February 28, 2017
A. The last few responses were more then enough to began resolving your issues. I couldn't help but think why not engrave your "rings" prior to the plating process? In my experience with decorative plating it is best to have all tooling, cutting, and polishing done prior to laying down any plating on the the surface. Seems to obvious so there is probably a reason you are not doing it already but just in case it was overlooked.
Chance Dunstan
Electroplating/Forming/Coating Manager
Placerville, California USA
March 8, 2017
Q. I wish to have a new stainless steel exhaust system nickel plated. Stainless for non-rusting longevity and nickel plating for original 1923 appearance. Can this be successful or Will the plating come off because of the heat? Thanks.
Max Houston- Sudney,NSW Australia
January 6, 2018
A. Hi Max. If it's done right the plating will not come off -- but how are you realistically going to find a plating shop which will do it right? If you can find one that specializes in nickel plating of stainless exhausts, fine; but if not, do you really want to risk repeatedly mounting and dismounting it, and fighting over it for months if the plating does bubble or come off? I'd probably go with nickel plated steel myself.
Is this a car or a motorcycle? It should be understood that the more interesting details which are included in your posting, the more you will draw the interest of the readers and inspire them to respond.
January 2018
It's a 1923 Sports car.
Three pipes come through the hood and 3 inch exhaust pipe runs around the outside of the body, so it's a feature of the car.
- Sydney NSW Australia
January 7, 2018
Q. Can Wood's nickel be replaced by copper while plating stainless steel 304? Is it possible to plate a thin layer of copper on ss directly, and then can be nickel and chrome plated like brass?
Rajesh Bhardwaj- Bhiwadi, Rajasthan, India
January 30, 2019
A. Sorry Rajesh, you will not get proper adhesion if you replace the nickel strike with copper plating :-(
January 2019
Q. I am doing woods nickel strike. Makeup ratio: 150 g/litre nickel chloride & HCl 25 ml/litre. Power 1.5 volts, 2 minutes time. Before this, doing soak clean and e-clean. After Wood's nickel, normal DM Water rinse, then bright nickel, after this gold strike. Doing this I face bubble problem -- nickel peels off like a bubble, please let me know which step I did a mistake.
Vasanth karunakaran
- Chennai, tamilnadu
May 27, 2019
A. Hi Vasanth. The fact that you are doing Wood's Nickel at 1.5 volts tells us that the workpiece is quite close to the anode, probably indicating that that you are dealing with a small part in a small tank, but it doesn't tell us the important part, the current density, which should probably be about 1000 A/dm2.
When a multi-layer plating does not adhere, it could be poor cleaning, poor Wood's Nickel, passivation after Wood's nickel, laminated bright nickel plating, passivation after bright nickel, or poor gold plating. Usually the most productive thing to do is to try to cut the problem down to size by doing your best to analyze where the separation occurs. Scrape off the blisters, and study the substrate in the blistered area, and the underside of the blisters, to try to ascertain whether there is no nickel on the substrate, a tiny amount consistent with successful striking, or a large amount consistent with laminated nickel plating.
June 2019
A. After you check what Ted says above, then , if you have left the anodes in the tank, most likely the metal content has climbed and the previous in-efficient strike has now become an efficient plating solution and dos not activate whatever the base. Information for the proper control of a nickel chloride strike is available.
Q. My question is instead of Wood's nickel strike can we utilise electroless nickel plating bath as nickel strike before zinc nickel plating?
- Delhi, India
August 2, 2020
A. Sorry Abu, that's probably a no. Stainless steel instantly forms an oxide surface to which plating will not adhere properly. The Wood's Nickel is a strong acid which can dissolve that oxide while the nickel plates onto it. I strongly doubt that any electroless nickel solution can attack the oxides that way.
August 2020
June 2, 2021
Q. Lately we've been having issues with adhesion of our Wood's nickel strike, which is plated on #8 polished stainless steel panels prior to electroforming parts.
Prior to strike, panels are cleaned using a 150 °F alkaline soak for 60 min, electrocleaned, then struck.
Rinse water is DI, averaging 17.5 MOhm.
Our original alkaline soak time and concentration were lower (for many years); I increased both to try to improve cleaning of the panels, but we still have the strike layer peeling.
The parts are not sticky/stuck to the surface; the bulk of the parts have no issue, we're seeing 20% or so failing due to this strike layer issue.
I have changed the strike bath as a test measure with no difference in results.
Is there a better method of cleaning the surface? I'm looking into permanganate/hydroxide chemistry as a potential test cleaner.
Thanks for any input!
- Colorado Springs, Colorado
A. Hi Jeff. While I don't know your parts, a 60-min soak clean followed by an electroclean sounds like a pretty robust cleaning cycle ... unless there are silicones about, in which case no amount of cleaning is robust enough.
So at this point I would suspect the nickel strike more than the cleaning. And, since you've already changed the solution, I would suspect inadequate current density. If you get a chance, please take a look at the adhesion chapter in Electrodeposition [on on Amazon or on AbeBooks (adv.)], which seems to indicate that you almost can't have too high a current density, but too low leads to "iffy" adhesion.
June 2021
A. You did not mention an acid dip following the alkaline cleaner, so I have to wonder how much neutralization you are doing to the nickel chloride strike. Inspect the raw metal with a 10X loop and look for holes. If your anodes are S-rounds then you must take them out between runs to prevent the nickel metal increase which converts the inefficient "strike" to an efficient non-bonding "plating" solution, but you seem to handle that buy replacing the strike, now go back and use Rolled Depolarized anodes for the strike. Tell us the alloy, is it "leaded"?
Thank you for the great info Ted!
I had been previously told the nickel was slightly high, about 1 unit over (1g/L). I checked the actual number today, and it is 15g/l over our target. Bath has been cut, hopefully that solves our issue.
Robert, thank you for the info!
I inherited this system, which does use nickel rounds instead of bars. I have sourced the bars, and will begin testing them once this current issue is solved. I will also look into an additional acid dip to follow our alkaline/e-clean process.
June 3, 2021
A. Hi Jeff,
You have Nickel peeling problem on stainless steel substrate, I think your process step may be revised , 1) soak 2) reverse current in electrocleaner 3) rinses 4) 10% sulfuric acid dip with 4-6 volt or 700-900 amps depends on your work load for 30 seconds 5) rinse 6) Wood's nickel strike.
Good luck Jeff.
Popatbhai B. Patel
June 27, 2021
Q. Activating S.S. - we are using Lead Anodes in the Sulfuric and carbon anodes in the HCl and both with current. What should the anode area for both tanks?
Mark WilliamsLab - Tempe, Arizona
September 8, 2021
Q. Can stainless steel be nickel plated? From what I know, ss can be nickel plated but it is not very consistent and a nickel strike is required for a more consistent plating. Why is nickel plating on ss not consistent? Is it because of the lower ferrous content? If so, is there any article about this. Thank you.
Shinji Kaworu- Penang, Malaysia.
December 7, 2022
A. Hi Shinji
We appended your question to a long thread on the subject which hopefully will answer all.
But in brief, plating must be done on metal -- clean, raw, non-oxidized metal -- so that metal can grow on metal. But stainless steel, due to its nickel and chromium content, instantly oxidizes and renders this difficult. Nickel strikes, especially Wood's Nickel, are highly acidic and dissolve those oxides and keep them from forming -- while simultaneously depositing a thin layer of nickel on the parts to make them more plateable.
But remember that nickel passivates fairly quickly itself, so the nickel plating must follow the nickel strike fairly immediately.
A. Mooney has got you covered. But when you say "not consistent", a frequent problem is that people leave the anodes in the tank when not in use, the nickel content goes up, the low efficiency "strike" becomes an efficient "plating" solution and does not "stick".
Q. Thank you very much.
The part that I am plating is made up mostly from steel and only small areas are made up of stainless steel. The part will go through electroless nickel plating and the stainless steel areas often present uneven plating.
Is there any suggestions to have a better adherence on the stainless steel areas? Is it necessary to strike the whole part with Wood's Nickel?
- Penang, Malaysia.
December 10, 2022
A. Hi Shinji
It is necessary to strike the stainless steel; it is permissible to strike the whole thing is that's the most practical way to strike the stainless steel.
Electrochemical Metallizing by Marv Rubinstein
or eBay or
Q. Thank you very much. But is it possible to strike stainless steel through brush plating?
Shinji Kaworu [returning]- Penang, Malaysia.
December 12, 2022
A. Hi again Shinji. Yes, brush striking or 'bonding' is certainly possible. However, it may not be easy.
A. Hi Shinji
There are options to strike the Stainless Steel with brush plating, but it looks like a hassle and probably it is not practical in your case.
If the whole part is steel and only some areas are stainless steel - it is much simpler and easier just to strike the whole part, rinse and immediately plate electroless Nickel on top of the strike.
Plating has to be done as soon as practically possible after the Ni strike. Keep the part wet all the way from Ni strike-to rinse-to ENi.
- Winnipeg, CANADA
