Letter 36098
Zinc Cobalt Plating
I'm doing Zinc-cobalt Plating over the mild steel im getting Black
deposit Burning Like deposit with proper current density ( 1a/dm2-
1.5v) please guide me 2 solve the problem.
Arul
Electroplating - Bangalore, Karanataka, India
You've given us almost nothing to go by, Arul. Hobbyist or
established plating shop? Proprietary process or homebrew? Barrel or
rack? Have you removed a coupon after preplate and immediately before
plating and completed it in a Hull Cell or another line? Have you
preplated a coupon on another line and put it through this plating
tank? Was the line functioning perfectly for months and stopped
overnight or is this a startup that has never yet run right? The
universe of possibilities remains the universe. Thanks.
finishing.com Inc. - Brick,
NJ
Dear Arul,
If you can be more specific about your bath, may be I can help
you.
1.What is the bath Chemistry- Acid Chloride-boric Zn-Co,Acid chloride
boric free Zn-Co or Non Cyanide alkalyne Zn-Co
2.Bath constituents (Do u analyse the solution?)
3.Cobalt conc.in ppm of the bath
4.Type of component u plate because the Current applied seems to be
lower than required even for acid chloride bath
5.How old is your bath and what is the volume
6.what do you do for the maintanance of the bath
If you furnish all the details, I will be able to help you.
T.K. Mohan
plating process supplier
Mumbai, India
August 15, 2007
Dear sir,
the problem of black spots is due to improper deposition of cobalt.u
can cantrol the same with variation in your votage of ur recitifier.
I have gone through the same problem long back.
Kiran Pamkar
- Mumbai, India
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
