Letter 36068 384 hour salt spray FAILING-Spec. WSS-M21P17-B3+++++ I have submitted parts with Plating Specification WSS-M21P17-B3.
The salt spray tests is for 384 hours. Thickness minimum is .00031"
(inches). The parts passed minimum thickness and measured @
.00055"-more than the minumum requirement. The salt spray however
failed @ around the 200 hour mark. Don Istvan
+++++ Dear Sir: Brian Chang
+++++ Don: The WSSM21P17 B3 specification calls out a specific finish that can only be applied by licenced applicators. These applicators are audited on a quarterly basis, and parts routinely pass the both the white and red corrosion requirements, with and without thermal shock. I suspect the finish you are evaluating is something other than what is approved by Ford Motor Company. Please contact me for more details Mike Wyrostek
+++++ I'll agree with everyone but would like to point out a couple of
other issues. First to Mike: Yes a specific product is specified
however, exceptions are frequently granted to products that produce a
finsih that passes the performance requirements of the specification.
This is partially due to legal issues (I prefer not to be more
specific then to say that they revolve around areas of anti trust
actions and collusion) and practical respects (the use of only
licensed shops would greatly reduce the pool if potential suppliers
especially in some geographic areas). Gene Packman
Dear Reader, please --
Save
