Letter 36052
Zinc Phosphating
[Ontario]
I process metal screw through a zinc phosphate immersion bath
followed by an oil dip but lately some of the screws are coming out
with a white powder on them which if rubbed off shows a beautiful
part underneath. This is normally the case when the tank is in poor
condition but lately, it can be when the tank is brand new. Could
there be too much phosphate present??
Carrie Habinski
Environmental Technician - Beaverton, Ontario, Canada
The white powder is nothing but oxide products of Zincphosphate.
You may require to increase the iron content in the bath, so that the
oxidation will be retarded. In a fresh bath you will have almost no
iron. You may add iron powder or iron wool to increase the iron
content to solve your problem.
V. G. Rajendran
- Trichy, Tamilnadu, India
It sounds as if this is sludge and hard scale from the Zinc
Phosphating bath, if the bath is fairly new the sludge /scale could
be coming from the tank sides, pipework, heater tubes etc, it is
quite normal to descale every one or two years to control this build
up,rinses esp those after the phosphate tank also get this build up.
I would not do anything to the bath itself, as this would again tend
to cause more sludge to form .
A Wagstaff
- Lincs, UK
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
